Jim, I do hold an import/export license and currently the rules are now simpler.
He can buy the boat, drive it home and register it, especially since there is NO GST ON A USED BOAT if bought from a private induvidual. There is GST on a broker's commission but that is the sellers responsibility.
If he puts new engines in the boat before leaving he would have to pay GST on the work done only.
Below is for new goods,
Exported goods
Goods (other than excisable goods such as beer and tobacco) that are ordinarily GST/HST taxable supplies may be zero-rated if they are exported from Canada. This means that you do not charge GST/HST on taxable sales if you deliver the goods or make them available to a purchaser outside Canada.
When the purchaser takes delivery of the goods in Canada, you do not charge GST/HST if the following conditions are met:
the purchaser is not a consumer (a consumer is usually an individual who is buying the goods for his or her personal use);
the purchaser exports the goods as soon as is reasonable in the circumstance after you deliver them;
the purchaser does not buy the goods to consume, use, or supply in Canada before exporting them;
after buying the goods and before exporting them, the purchaser does not further process, transform, or alter the goods in Canada, unless it is reasonably necessary or incidental to transport them;
you keep satisfactory evidence, for audit purposes, that the purchaser has exported the goods; and
if the property being exported is electricity, crude oil, natural gas, or any good that can be transported by means of a wire, pipeline, or other conduit, the purchaser is not registered for GST/HST purposes.
