PVC for winter tarp
gardnersf
I will be covering my boat this weekend for the winter. I woudl like to build my frame for the tarp out of PVC in order to reuse the frame and re-assmeble easier next year.
What size PVC woudl you recommend? Boat detaisl below
I was thinking of 1.5" PVC with vertical supports every 5-6 feet and supports out to the rails evru 5-6 feet. Then cross hatching clothes line between to provide additionak support.
I used 1 1/2 inch PVC for my frame...I have used the same frame for 5 years now...Pics below...One thng I am going to do this year is to put 1 1/2 inch styrofoam on the PVC to stop the snow from sagging between the suports...The styrofoam wont take much weight, but the slope is enough to let the snow fall off without sagging between the pipes...
This is all a one time output in money, so I believe it is worth it...
I just had the boat moved to my yard, and here is a pic of the frame before it's on the boat...
I use 1 1/2 " PVC on my 34' flybridge boat with a 50 X 30' silver tarp. My PVC frame is a 1 1/2" backbone with legs about ever 4 feet. I don't tie it in with PVC pipe to the rails but use 1/2" nylon strapping tape like that used in shrink wrapping to tie it to the rails about ebvery 3 feet. THis makes it solid and it won't move and water won't puddle in the tarp. I thought using PVC to the rails was overkill because if you look at a shrink wrapped boat, you'll see the same strapping tape holding the 2X4 wood frame to the rails. I've used this frame several winters now and have been happy with it. The PVC is a lot more manageble than 2X4s so I can do the whole thing myself. Just be sure you have enough pitch so snow and water run off.
I just built a similar structure to cover the 300 DA. I have a 60 x 40 tarp in it's 6th year that covers the whole thing. It works great and has lots of pitch to shed the snow. I just duct tape the pvc over the railing to keep it all tight and firm. A couple of years ago, I notice the tarp wasn't shedding the snow like it used to so I hit it with some silicone spray! The snow doesn't stick at all anymore!
Greg:
Can you tell me where you bought the tarp? That is exactly the size that I need.
Have you got any pictures?
Joe
Joe, Tarpsplus.com. 30 X 50 works well for me. Loa 39' 4" and 13' beam with a flybridge. Covers from bow pulpit to transom. Doesn't cover my swim platform. Iff you get one too long or too wide, you can't tie it down tight enough. Silver tarps have grommets every 18" and I use about all of them. Don't waste your money on a blue tarp, not strong enough. I get at least 3 years out of each silver tarp and I use the PVC frame every year. No pictures, just put it on today. GReg
Yep, truckers tarp is the way to go. Black on one side, silver on the other. Grommets and black nylons straps every 4 feet to use as a tie down. Solid and HEAVY! The 60 x 40 is around 100 lbs!
In AK I used plain ol' lumber as PVC will snap in the extreme cold.
I put a cover of 6 Mil clear plastic for the water proof part. Then coverd that with a WalMart rip-stop looking stuff. Light but strong and slick enough that nothing stuck to it.
The Blue tarps will leak, probably any tarp will leak eventually, and the 6 Mil was the water proof part, but it wont stand the rigors of sun and wind so I needed the tarp over top.
I used jugs half filled with water as tie-down wieghts.
Thansk guys, I ended up with 2in PVC. I was worried the 1.5" would sag too much. I have a pretty wide boat and I hadn't had a chance to see the responses.
I'm sure the 1.5 woudl have been fine but not a lot of difference in cost.
I have a 30x50 (or 55, I'm not sure) it works perfectly. Here are a few pictures in progress. Took me all day but next year I can just reassemble,
I didn't get a picture of the finshed product, but basically it continues up over the radar arch and then come down in an elbow. I didn't think about having an elbow come off the bow rail first. I cut the middel out of tee connections for connection to the rail. I then took clotheline and spiderwebbed it between the rail and PVC. I have a heavy green tarp with black back. The only downside is it gets dark undernetah.
I'll post more pictures if I take them.
Greg:
I am looking at the site. Which category did you selcet to find the silver ones? Truck, Boat?
Joe
Squirrls!!!!
When you make those nice winter homes you should remember to go out and check for Squirrels every once in awhile.
If you keep Important Books on board, keep them in a Plastic cooler with a good latch on the lid. They wont get wet and the Squirrels cant get to them.
PS: Weiner you must be a Structrual engineer. Nobody but an engineer could figur out how that went to gether and stayed up when assembled! LOL.
It's not that bad to assemble...It's only in 3 sections...Each section is glued together...
As far as squirrels,barn cats and coons...they get taken care of...
Throw a couple handful of mothballs around to keep all little critters from exploring and using your boat. If the odor isn't completely gone when you untarp your boat, a few sprays of Fabreze will do the trick. Fabreze will take out any musty odors as well.
Careful hangin blts. of water for weight. I have a neighbor that does that one a lift ( once) till they froze and with some wind, banged the heck out of his gelcoat. He still uses blts, but they are the pink stuff. Problem was solved.
I also use PVC for my frame, with the T sections attached to the railing. One thing you might consider adding is chafe protection on those T's. Hardware stores sell 4' lengths of foam in a tube shape designed to insulate water pipes. I cut lengths of about 6", and attach to the T's with 2 wire ties. Bob
RMS, Good idea. I actually cut up some terrycloth and put it inside the T. but that foam would be better.
