Vic,
These seals do not rely on any part of the shaft itself to make the seal. There is no packing gland. The seal is made by two component of the seal, which is new. There is a stainless steel ring that turns on a fixed carbon ring which is held in place with rubber bellows.
Winters, I have the same seals which I replaced because they were dripping at rest and still had the same problem.
First two things to try are to clean both mating surfaces with 800 wet dry sand paper. Make sure the bellows are compressed enough and make sure the the bellows are not pushed all the way on to the shaft log (Stern Tube) Depending on the length of the stern tube, the tube should not extend so far into the bellows such that it reached the folds of the bellows. Loosen both hose clamps on the bellows around the stern tube and pull the rubber seal forward like you are pulling it off the shaft log. Just don't pull it all the way off it should only go in about an inch. This will give you a little extra compression.
Once you do all that, look at the two rings and how they are aligned. They should be concentric or centered on each other and lined up. If they are not, it means that your shaft is not centered in the tube. That was my problem. If it's just slightly off you can loosen the clamps and the shaft log again and try to align the bellows so that the rings line up better. Try putting the transmission in gear at idle speed and look at the rigs. Make sure they stay lined up and there is no wobbling.
If there is misalignment or wobling, then you may have a bigger problem like a bent shaft or strut. That will likely cause a leak and need to be corrected first.
In my case I was able to move the engine to better align the shaft in the tube and then align the engine to the coupler. Everything is in alignment now and it does not leak.
Be sure everything is tight when you are done, all the clamps and set screws. If the stainless steel ring slides forward on the shaft when you are not around, it could be catastrophic. A huge amount of water will come in between the two rings if they are not in contact.
