Originally posted by carmac
David -...and my thinking is that a very high quality hull will have less problems long-term, even in relatively easy service. Wouldn't you think a 25 year-old Formula would have a lot less problems than a 25 year-old Maxum?....
You are going to make me revive a brain cell I have been trying to kill for decades.
In 1986 I bought a 1979 Formula 233F. The deck was a bit spongy and I knew it needed replacing. Not a problem. Saber saw the deck, some plywood, fiberglass, wax and I am out of here to fish off Jax Beach. I was looking at 10K max to do my plan.
WRONG! WRONG! WRONG! $30K later (long story with a sinking, engine and outdrive theft, and a 3 year tour in Italy in between) I had my boat.
The little bit spongy deck turned out to be saturated A/B foam, waterlogged stringers, rotted motor mounts.....etc, etc, etc...
I could have had a 1980 24 foot Sea Ray cabin cruiser with 6'4" headroom vs. a cuddy cabin, A/C, stove, fridge, slept 4...PLUS was toting a brand new 260 Mercruiser and sat on a brand new aluminum trailer for $12K. That extra $2K was too much to spend!!!
Point is, an abused Hatteras can't hold a candle to a very well maintained Bayliner.
A survey is a must, both hull, combustion and running gear. You are better off with what suits you than what the name on the side of the hull is.
Mrs. Robinson was completely enamored with a 48 Sea Ray bridge...until he got on it. Much smaller inside than it looked on the outside. Greg will be one of the first to tell you he just likes Sea Ray's. After that tour, he widened his selection criteria to several other brands. Primary reason was head room. There is more in his 330 than there was in the 480. Go figure!
HTH
