Quick Connect on AC hose
Squber
On another thread I have been reding about issues winterizing the AC system with more thanone overboard discharge. I have a 2005 Silverton 34 C and had problems with mud daubers blocking the forward AC outlet in the spring. The year after we got the boat I installed a bronze garden hose quick connect on the hose going forward just after the Y. It allows me to hook up the forward AC directly to the marina water system to flush out anything (which the AC pump wouldn't always do sine water just went out the stern overboard. Even a couple of inches of mud dauber nest comes right out. Since my boat is almost always in the water is is hard to get at the forward out let. Making sure the forward AC is winterised is also a snap since I can just use a compressor to blow it out from that point and then I can hook up a drill pump with a quick connect and pump with no problem.
Initially I was worried about corrosion so I check the fitting pretty regularly and keep it greased with silicon grease but so far no issue after 4 years.
I do, however, make damned sure that it is solidly connected each time I put it back together.
Anyone else do anything like this?
those fittings do restrict flow but if it works for you why not?
An other easy clean out is to use a small hose nozzle that fits into the outlet and garden hose taped to a boat pole to blast back into the system with the pump running. A few shots and junk comes out.
