radar dome location?
Instigator
I was told that mounting the dome (2kw ) on the front of my flybridge was not safe and that it should be above your head.At the marina this summer the number of bridge boats with the radar mounted on the front of the bridges were plentiful.I dont have a hard top so the other option is a pole mount(not very cheap).
Some people say it's ok, some not. I had one on the front of the flybridge and every time I turned it on, it bothered me. We all agree it seems, that it should not be directed to your head, but my logic was, if it was not good for the noggin, it was not good anywhere else, especially if you were in the child bearing years.
I moved mine to atop a 10ft box pole I built out of poplar (too cheap to have a pole fabricated, mahog and teak were too heavy). Even built a mast step. It worked out excellent.
Be sure when you are done, that it still is up high enough not to be encroaching on your brains. Most shoot a beam width of 25 degrees, 12.5 up and 12.5 down from front of the radar. And on most boats you want the thingy mounted with a 5 degree down angle (on a powerboat) to account for the fact that the bow raises when you move forward. (not the case in all instances, depends on the boat type).
So, my short answer is I moved it out of harms way, one less thing to worry about. There is not much in life you can control, but this you can.
If someone can tell me how to post a picture I will post one.
People who mount their radar in front of their face are just plain stoopid. The radar transmits microwaves...same as your microwave oven. First thing it'll do is start cooking your eyes(cataracts)
We have big a$$ed Furuno 120 mile radars offshore where I work.
One on SW corner and one on NE corner.
They are set up to where they don't put out when facing the platform
where people walk and work. I am not sure if the smaller ones can
do that. But you might check and see if your unit can do it.
I have seen a lot of dome type radars like that and even an open
array one on a 58 ft. Hatteras where I keep my boat.
It is not a good idea in fact it would not meet the FCC specifications for maximum permissible exposure even in controlled environments. In uncontrolled environments which a boat would be considered it not acceptable according to current FCC MPE limits set about 5 years ago. Get it over your head by at least 2 feet and then you will be under the power emitting from the narrow beam. Mine is about 3.5 feet above and slightly behind on an arch.
You can probably get an idea of the impact of the radar located where the beam sweeps through the bridge if you can evaluate the captain's children, if any.
Besides early childhood spontanious combustion, what are the symptoms?
The temptation to respond to this is really high but I might accidentally offend some of the more PC on the forum!
Most radar units have the ability to 'blank out' a sector of thier transmit path - - say, setting a 'no transmit zone' from 120 to 240 degrees. Sure, you'd get no radar info from that sector (but you wouldn't get a return anyway - your bridge is in the way!), but it'll save your personal-body-parts from excessive microwave radiation!!
My Furuno w/ 2Kw dome has such a feature.
yeah, and once you see an early childhood spontneous combustion (ECSC), you'll never forget it.
Is there an instrument that could measure the radar output at different locations to determine hot spots?
since its only a 2kw unit it may not be an issue. contact the mfg. of your unit for installation specifications. if your specific question is not addressed in the specs call them and speak with tech support. i'm certain that someone there has data to support this type of question that is based on facts. if you were running a unit above 5kw i'm certain it would not be acceptable to have people in the line of fire.
anyone that runs a radar transmitting through their body is making an important contribution to improving the gene pool and should be thanked.
Most of us in the medical profession advise against exposing the body to microwave energy. The most suscepitable tissues are the lenses of the eyes and gonads. If you have the radar screen at the lower helm, and never run the radar when people are on the flying bridge, then it might be acceptable.
In reality, there is probably very little risk. The time of exposure is very short, and the amount energy decreases rapidly as you get further from the scanner.
Radar waves go through fiberglass easily--consider what the radome is made of! I prefer to be able to see what is coming up from behind me on radar, as well as what is on the beam and ahead.
It's really a non-issue. And as Bob has pointed out, there is little or no risk.
Bob this would not pass the FCC's Maximum permissible exposure limits in either controlled or non controlled environments. Also Bob did not say it was 100% safe. He gave conditions you use the monitor in the lower helm and not run the radar when anyone is on the bridge. People complain about cellphones well to give you an idea a cellphones maximum power output is 600milliwatts or 27dbm a radar unit is a bit more than 2000 watts or 58dbm for the lay person this is tremendously more powerful both units transmit in pulses so it is a good comparison. I would never subject anyone in my family to this level of power density in the beamwidth of the radar. The signal does not leave the radar unit in a straight line more like a cone. I can calculate a link budget at 5 feet at 10ghz the approximate frequency most radar units operate at and 2kw and that is about the least powerful radar unit.
This topic maybe mute because there are new high definition low power radar units that should hit the market within the next year.
Good thread, last boat I bought has that irritating "radar mounted on the forward section of the bridge" syndrome. It's on my to do list to move it. Seems to be a mixed opinion here, I always thought it was a "real bad" thing to do, but surely with so many boats having them mounted there, there would be real life danger/caution/warning labels advising not to do so. There's companies that manufacture specific brackets for this type of mount, and we all know most mfg's. lower stations disapeared some 30 years ago. All the CO2 warnings we hear, but none other than "advice" on the radar thing. "Radar for Mariners" I believe discuss's this topic. Food for thought: Don't CG reg's require boats with radar to have it on at all times?
my disturbing install
ry%3D480
I notice every boat around this one has the radar unit properly placed. The mounts may not be for the specific place they are used in, that same mount could be used on top of a fiberglassed radar wing style arch or hardtop. I really think it would be a good idea if you move that radar unit. The other point is yes if your ship has radar you are required to use it.
I don't think it is a regulation. I see work boats, commercial fishing vessels
and crew boats running around in the river and in the gulf without the radar running.
If so, it probably would be for USCG inspected vessels. Not private pleasure boats.
