- Apr 4, 2009
- 31163
- 2,834
I can confirm beyond a shadow of doubt, just as stated above, if your vessel, commercial or recreational, is equipped with a radar you are required, by law, to have it on and monitored any time you are under way, making way or not. My old boat had a 36" open array and I had a young and energetic Coastie stop and warn me of just such a thing in Jacksonville about two years ago. The young lad saw my array not turning when I was approaching a fuel dock. He promptly ambled over and advised me that it had to be on. He was actually quite polite and informative in the matter.
Originally posted by Radioactive
"Can you connect the dots for me?"
I can see where you believe that the Rule does not force you to operate the radar at all times. And this, in fact, may be the case. It is a very fine line however.
What you are -not- addressing are two things: 1) Radar is -always- useful, even if it is not always your primary tool for safe navigation. 2) If you -ever- end up in court, criminal or civil, you WILL be asked if the radar was functional and in operation. And if you state that it was off, it will almost certainly be detrimental to your argument.
Which brings us back to the common sense argument: Required by law or not, it is best practice to use the radar at all times. This promotes familiarity with the unit and the display's relationship to the "real" world. By always using it, the actual mechanical skills to operate it effectively become second nature. And you ability to interpret what is displayed is improved. Radar will show more clearly certain objects than the Mark One Eyeball, making it a useful adjunct to all of the other commonly used safety/navigation tools available. Using the radar at all times is a good habit which will help ensure that if conditions DO suddenly go South, you have the needed tool up, operating and tuned already and will not need to be distracted while you fire it up.
Other than irradiating personnel, which can be avoided by proper installation, I see no good reason for not operating the radar whenever operating the vessel.
