radar mountihg pole
Instigator
I have a radar I would like to mount on a pole.I have a flybridge with a canvas top and was hoping to get something i can install with out having to pay for a custom job.I am located on long island any ideas to keep the cost down.
Do a google search on "Radar pole mount" Many are made for sail boats, but easily adapted to power boats. It helps if there is something to brace the pole on--such as railings. If not there need to be braces--one fore and aft and one athwartships. The pole is usually from 2" to 4" in diameter. It can be outside of the canvas bimini top.
My stuff came from Edson Marine.
Good luck
Niles
Niles, you wouldn't have a closeup where that meets the rail, would you? Is a rail mount the only bracing you have?
The Seaview product looks reasonable but at Worst they only seem to sell the rail mount in a package with a brace, which would not be in a good spot on my bridge.
I need to do the same thing as Instigator, a friend gave me his used-but-works-fine radar when he upgraded and I'm considering adding it to my boat.
Les, or anyone else, know if Boatfix has the SeaView taller pole mounts? Or some other brand? There seem to be a lot of Seaview items but it's mostly the accessories or the shorter mounts.
Yes the rail is it. As you can see from the pictures I have issues. When we bought the boat the mount was broke and I bought a new one from Edson ($120). When I torn down for the winter last fall that one was cracked also. I have had one fabricated where I work and I don't think it will break.
Niles
Niles, thanks! Great info. The Seaview one does not seem to have the plastic parts, it is more of a standoff with two metal arms so maybe it would hold up better.
I guess I will steer clear of the Edson mount.
What did you make - a flat metal plate with holes for the u bolts?
I had the same issues with my rail mount. Mine is exactly like yours. I put heavy SS washers on the outside and it still works great. There isn't enough plastic to use the recessed nut installation.
Ron,
My machining guys made a copy of the original out of a block of high pressure laminated plastic that we also make. They made it a little thicker and I need to get new u-bolts so for now I am using the "good" half’s of the two broken ones to make one good one. If the home made one doesn't hold up I will add a standoff, which I probably should have anyway. I think it is more that than the Edson part.
Good luck
Niles
Capn Tony, excelent point, I will try that
Niles
I got mine from Nautical Creations in Louisville,KY.
4" alum...painted white...I recall it was about $450.
Instigator - are you still looking for one of these? I have a line on a used one, on Long Island, very cheap. It seems to be identical to what Niles has.
I'm no longer in the market for it as the radar I picked up has issues and doesn't appear repairable.
