Rafting together
Good subject, have always deployed fenders and tightened lines as much as possible as figuered if looser than have more room to pull apart and slam back together. For no particluar reason never used spring lines, just fore and aft, but will try the springs this summer, makes good sense and think will help to eliminate a lot of the movement. Might work to be able to tie a little looser and let each boat ride on their own if controlling the fore and aft movement.
The one thing I have noticed is the best way to tie up really depends on what size/type are rafting with.
I think rafting together is one of the most fun things you can do on a boat. Everyone has their own space but you can hang with your friends. As for tying up, if I'm on an anchor I like every other or third boat to have an anchor out. And I prefer it be the heavier boats. I raft with sailboats that weigh 8k lbs more than me for the same length so I would rather have them on the anchor and tie to them. Tight vs. Loose not too sure. Neither is good. I was taught that when you have it right, the boats should float and swing together without much in the way of rubbing or jerking.
I won't raft on an anchor overnight. Too much trouble if you start to drag in a blow and have to move and reset quickly. But on a mooring we often anchor overnight. It's almost mandatory in crowded spots like Block Island or Cuttyhunk if you are with someone.
Don't think there is a perfect way to raft up. I do think the bigger the raft up the less movement due to wave action, atleast for the boats further down the line. It's the boat or boats on the end that have the biggest impacts and forthose I say you just over do the fenders and tie the boat tight enough that the fenders are able to cover the full range of motion.
We personally don't mind rafting up with friends for good times. Now a few lines secured to shore(we are lucky for that option) ensure no drifting away at night!
I rafted a lot in CA but never in FL because there are too many wakes.
I raft up 6-8 times a year. I use 3-4 fenders and keep the lines somewhat tight; not like a piano string. It makes going boat to boat dryer. There is no need to hop in the water to get to another boat. If there is a chance of thunderstorms rolling in after dark, I will not raft up at night. There is no way I want to wake up at 3 in the morning after drinking till 2 in the morning and have to untie, reposition the boat, and anchor. Storms usally mean high winds and I single hand half the time. I like to get settled in and away from other boats prior to drinking and dealing with bad weather.
You need an "anchor nazi" when you raft up
We raft almost every time we go out. The important thing
is for everyone to be on their own anchor, use spring lines
and fenders, and most importantly, permit only similar sized
boats next to you. I know it sounds snobby, but the fact is
similar size/weight vessels behave/move similarly, almost in
unison to waves so line stress is minimal. With a big difference in size, you have to raft "loose".
There's an added detail in our case with certain other sportfisherman
type vessels. We have to watch out for spreader "swashbuckling" LOL
We line up our swimsteps and tighten then lines to the point that we're not drifting apart, but there's a little 'give'. Lots of fenders in protected waters.
Generally, I wait for Absoloot to get situated before showing up and tossing him a line. It's always worked for me...
I agree with most of the respondents, lots of fenders, only on calm water then bow, stern & spring lines snug. We try to alternate bow and stern anchors so that each boat has one anchor out ( I usually put both out for MY piece of mind)
We are every weekend rafters. Overnight, not just day rafters. We are firm believers in in tying them loose. Let them 'breathe'. The longer the lines between cleats the better.
No attempt is made to raft stern to stern. When rafting with different styles of boats it is much more important to raft so that people can cross safely from boat to boat.
We do not use bumpers when we raft!
This was our Harbor Dinghy Run this year!
Ken34,
Where was your group inflatable boat shot taken?
Somewhere over near Jefferson Beach or the Clinton River area?
Mike.
This is how we do it on Lake Cumberland. My boat is the one near the end.
How do more than one of these mass-raft-up's set their anchors? I'd be interested to hear the process of multiple 35-40' trawlers rafting up and having more than one really get their anchor set.
Uh-oh... here we go with another anchor thread! How does it always come to this?
Tom,
We boat in the California Delta and that was our raft out in FlyWright's pic. Normally the first boat drops anchor and sets it well. I encourage others to pull forward, drop their anchor and set it then back down into the raft out which is what I do. Most of our club members will tie up and then deploy their anchors using dinghies. I don't think you get as good a set, but in most cases it is adequate due to the number of anchors and relatively calm waters.
Nice boat, is that you waving???
Split decision- Yes thats on the Clinton River, just east of Jefferson. That is South River road you see in the background.
Here are a few Raft - Up pictures
Muskamoot bay Raft up 2010
Jobbie Nooner - Gull Island
By the way- I snug my lines up, not overly tight, and only use a spring when needed!
