- Jan 29, 2002
- 7357
- 2,391
OK, 2 things...I'm 99% sure no AC units have condensate go out with the cooling water. Take a good long look at your AC unit and figure it out.
Also, you need to spend time in the bilge and find the pump that pumps out the shower. It HAS to be accessible. There should be a small plastic sump container that the shower drains into. Depending on the type of pump you have, it could either be inside that box, or just outside of it.
If you have trouble finding it, turn it on and follow the sound. You will find it and if there is a sump box, I'm betting it will be nasty.
