raritan Marine Elegance wiring question
So, in looking at the marine Elegance specs, I see it comes as simple flush or their smart flush which has multiple options for how to flush. The options seem nicer than just the push button flush so thinking I want to go that route.
Question:
What are the 12V wiring requirements for the smart flush vs. the simple single push button flush? Right now I have just one set of 12V wirings coming into the Jabsco electric head (model 37010).
Does the smart flush set up only require one set of 12V wiring to function or what? If I can do it with the existing wiring that goes to the head then I am good to go. If I have to run more wiring then I am not sure. :)
I'm very happy with the Smart Flush control and I'm glad Vic talked me into it. From my memory of my installation a little over a year ago, the control panel doesn't get a power feed. I think it's Cat-5 cable from the same control panel all the ME models have. I don't think it'll complicate your installation at all and you'll enjoy the options that panel gives (like "Water Only", "Water Saver Flush", "Normal Flush", "Empty Only").
Here's the manual w/ installation instructions: http://www.raritaneng.com/pdf_files/Marine Elegance/L460v0210.pdf
What Kurt said +1. Absolutely go with the Smart Flush.
He is correct, there is only one 12v power feed. The control panel is a Cat5 cable that connects to the main control unit.
Trust me, it is really a simple installation.
