My new to me boat uses raw water (salt water) to flush. All is working well. I used to use a powder called Oda-(something) in my old boat that had a fresh water flush. What is the best odor prevention I can use that works in salt water applications?
That is cool as hell! It never ceases to amaze me how much I learn on this site! It has an injector on the discharge side if the raw water pump.
The price is'nt bad either.
No Phil, the adapter is on the intake side of the raw water pump. As it draws in outside water to rinse the bowl, it also draws in a small amount of the deodorant mixture. It mixes with the incoming water to sort of pre-treat the incoming water before it gets into the actual toilet bowl.
