Rebuilding Vacuflush T Series on 330DA
BVasily
Symptom is higher than normal current draw, and pumping that last almost 1.5 minutes. I doubt leaks as the pump does not cycle more than once every couple of days. I have replaced duckbill valves. I disassembled the discharge pump, and noticed its gotten very stiff. I am not wanting to rush out and buy a new discharge pump ~$750 if I can rebuild this unit. Has anyone done this successfully?
Thanks for any advice and guidance as to the best place to find the parts ... if available.
Also ... I will need to replace at least some of the tank sensors as the 3/4 full indicator does not read.
Bob V.
Call Mike Starito at Northeast Sanitation. (800) 353-4323 or (631) 752-7606 or
info *at* northeastsanitation.com - he can advise you on what to do. Be sure to mention that you're in Ontario; there may be a parts source closer to you. Mike is in Farmingdale, NY - on Long Island.
Vic, thank you. I spoke with Mike and he as pointed me in the right direction.
Much appreciated.
Bob V.
