- Mar 2, 2000
- 36
- 6,657
The question I have is if you glass over the hole how much glass should go over the inside edge of the hole? I figure there will be some compression in the area thus a thin coat might crack? Of course and regardless of glassing it should be covered with epoxy once the cut is done and verified correct. So yes, coating the keyhole with epoxy would certainly be a good idea. Again, if you coat it entirely before installing it, clean off the blush and sand it with 80 grit (see West System tips).
So this replacement has 3/4 over all of the transom and a double thickness around the keyhole that does not extend to the hull sides? If this is the case I might assemble the two pieces outside the boat. If it does go to the hull sides, consider checking the template or making another prior to cutting the second piece.
On an aside, West Six10 tubes are expensive but for filling voids/cracks they are worth it. Forget about using the empty caulk tubes West sells unless you can slow down the cure enough and find a way to load them.
