recommendations for a new cooler please!
defboat
Looking for a new cooler that will hold ice for at least 24 hours. Would like it to be approximately 2 foot by 1 foot and tall enough for that bottle of wine and bottle of soda to stand up.
Any websites would be appreciated! Thanks!
Coleman Extreme, works very well!
Coleman Extreme.. very good cooler ..try Sport Authotiry ( if you have the sporting goods chain close by)
The best ones I've found for keeping stuff cold are the LoBoys; they have twice the insulation of most others their size. They don't hold up as well, but at the price...
A third vote for the Coleman Extreme....lasts all weekend long...
Just be glad you're not "stuck" with a 25qt standard Igloo that is quite poor, at best. Regal, for all their quality and innovation, saw fit to specifically design a cockpit cooler holder that ONLY the Igloo will fit. :( YES, Coleman Extreme!
Very interesting that this thread would show up today because my old red Igloo Legend 50 finally bit the bullet on the boat last weekend. The drain cap just cracked into pieces.
It's a 50 qt. cooler that I load with one 10 lb. block and two or three 10 lb. bags of ice. I keep it covered with wet white towels (evaporative cooling) at all times and it will keep drinks and food cold for up to six days even during 90-100+ degree weather. I've gotten 5-6 days out of this cooler several times during the last year or two (since using the towels).
So, I'm looking for a new cooler too, only 50 qt., and want the best that's out there.
Anyone have experience dropping a cube of dry ice in the bottom of the cooler and then putting regular cubes on top? I've heard that will make even the most average cooler last a while.
I like the idea of the wet towel on top of the cooler too, that makes a lot of sense.
Kevin
Kevin
Don't try mixing water or ice with dry ice. At the least, you could make some very cool fog. The right amount might freeze the ice into a solid mass. At worst: dry ice hitting water may cause an explosive reaction. http://www.metacafe.com/watch/310319/dry_ice_vs_real_ice/
I'd use one or the other, but not both together.
You also need to provide ventilation for dry ice: it evaporates as carbon dioxide gas.
Originally posted by Reel Antsy
Well this one claims to hold ice for up to 5 days...
http://www.boatfix.com/catalog/448.pdf
The best part is that you can buy it from Boatfix!
Jamie
BoatFix has the Igloo Marine 54 qt. for $45 and the Igloo MaxCold 50 qt. for $53. It looks like BoatFix has the replacement drain plug for my old Igloo Legend for $5 (darn!)
Igloo calls the the Marine and MaxCold "5-day" coolers. Except for color and size, they look the same.
Coleman calls the Xtreme Marine a "5-day" and the Ultimate Xtreme Marine a "6-day." That extra day will cost me 2X the price of the other three coolers.
Maybe I'll buy the plug and keep the new cooler on the boat.
Choices, choices...
You could always build your own and make it whatever size you want.
I have an Igloo Marine Ice Cube cooler. Works great! Holds the ice for days when camping in hot weather.
Thanks, yzer. That video was pretty amazing, I can just imagine that happening on board in the cooler - not good. I'll stick with regular ice and use the wet towel thing that you posted.
Kevin
That wouldn't happen in a cooler. The explosion was caused by an increase in pressure inside a capped plastic bottle. Dropping "dry ice" into water will release the CO2 as a fog. As long as the gas can escape, there won't be any problem. I've put "dry ice" in coolers many times, and it does work well. There is an ice plant near here that sells dry ice in blocks.
Here's sone facts:
DO NOT store dry ice in an airtight container, or in an ice chest with the latches locked down. The gas pressure of the sublimating solid dry ice will become explosive. Even if the container does not rupture, the force on the lid or top may be enough to cause severe injury. Leave the lid unlatched. As pressure builds, it will be relieved and kept safe.
Keep the cooler or container in an area with good ventilation. Carbon dioxide is heavier than air and will settle in the lowest areas of a room. The best place for storing a container with dry ice is a garage, or room with a ground level door or window that can be left open.
Wrap dry ice in a towel or newspaper and place on top of items to be kept frozen and below items to be kept cool.
Do not allow bottles or cans to come in direct contact with dry ice. They will freeze and may rupture as their content expand.
Dry ice is a solid with a temperature of -109 degrees Fahrenheit. Contact with bare hands or skin may cause severe frostbite. Touching dry ice can be like touching a hot coal -- the cold can burn just as quickly and just as severely as fire.
Depending on how often the cooler is opened, contents will stay cold for three to four days.
Do not allow children to play with dry ice.
