My tender is way over-propped from the tender dealer. Of course, I am now cruising and the dealer is non-responsive.
I have a new Evinrude etec 60 hp motor. It has a 13.25" x 17" stainless steel prop. I am only getting ~4300 rpm when it should be 5500+.
Should I just reduce pitch or should I consider a different diameter as well?
Also, I assume props are made to fit different hubs so I would need to find a make that fits this model of outboard? (Never changed a prop before).
Thanks!
Thanks!
