Refinishing a teak table?
RM
Our dinette table has various scratches and minor gouges and stains and I would like to refinish. What is the best method? Currently is an oiled finish but also considering a varnished finish.
Should I clean an brighten like outside teak or is it better to lightly sand and re-oil or varnish? How will previously oiled teak look when varnished?
Thanks for any tips.
If it's solid teak and not a veneer you can be fairly agressive. I've used bleach right out of the bottle to clean dirty swim plateforms. You have to use a soft scrubber so you don't destroy the softer grain and create ridges. Once it's clean, sand it to make it smooth. Oil or spar varnish will work. It depends on the look you are after.
I would be careful of how you start the refinish work on indoor "furniture." That is different than outside woodwork. First, anything you do will probably ruin the patina.
Personally I would probably stay with the oiled finish. What you depends upon how badly dented and scratched. Dents can sometimes be removed with heat. Use a damp rag and an old iron.
You might start off trying 0000 steel wool. That will degrade the current finish as little as possible. If you have deep scratches and dents then probably sanding will be required. I would first try sanding without doing anything to remove the current finish.
Of course much depends upon whether or not you like the current color of the finish. If you want to change color then all I said above is worthless. Go ahead and bleach or whatever then stain or let age naturallly.
Whether or not you varnish/shellac or remain oil is just a personal preference.
G
Teak is naturally a very oily wood which is why many people simply reapply the oil keeping the more natural finish of the wood. I did apply spar to some teak on the boat (7 coats) but I spent a great deal of time cleaning the wood with a diluted muriatic acid solution and paint thinner to remove as much of the natural oil as possible. If you don't do that you run the risk of having whatever finish/sealer you apply not holding and the material will soon begin to separate, flake off and just leave you with another, bigger refinishing job. As with any wood finishing task, the best results are only obtained with good prep work before the finish is applied.
