1996 Crusader 5.7 350CID
Two years with this boat noticed small amounts of oil in bilge. Of course...used battons to clean. This year, found good amount of oil in bilge during prep. Oil was changed during winterization so I know oil levels were close to dead on. Very low now. Cleaned bilge added quart and a half and ran up engine. Ran great, oil pressure good (although this motor always seemed to run lower than the other).
Noticed oil dripping from what looks to be adaptor for remote oil filter. Can't really narrow down if it's the hoses or the adapter itself as .....of course...it's the engine where the remote is against the starboard bulk head. I'm thinking of just replacing the whole thing. I think I found the right one for $219 but wondering if maybe there's something else I should check first.
Splashing on Wed so most likely won't fix until after that but of course will monitor bilge and use my "bucket head" to clean bilge if it leaks anymore (I know what's coming
Anyone???? Thought at first I blew a motor, much happier to find a simple leak.
Almost thought to remove adaptor and just put oil filter direct to motor. Is that something I can do in the short term?
Any help would be most appreciated.
