Removing barnacles from a dinghy
folieadeux
Last summer I left the dingy tied to the dock for about 3 weeks so we could do quick seafood market runs down the creek and when I pulled it out the bottom was covered in barnacles. I scraped all the big shells off the dinghy and I plan to apply bottom paint this weekend. The dinghy still has small rings and imprints imbedded in the bottom. I am afraid to use sandpaper or harsh chemicals for fear of damaging the dinghy material. Any suggestions for getting these little barnacles shells before I paint?
A muriatic acid solution with water will do the trick, and it will not harm gelcoat. There is a product called On&Off that does the same thing. You can get the muriatic acid for a fraction of the cost. If your afraid of the acid try straight vinegar.
I don't think I'd bother with the vinegar. It works but in my experience it's sloooooow. Muriatic acid from the pool place and BE CAREFUL!
This is an inflatable dinghy, no gelcoat. Think the acid is ok on the inflatable material?
Maybe you'd better stick with the vinegar; I've never tried acid on an inflatable. Better safe than sorry!
Neal, have you tried a razor blade?
Sorry, bad joke.
Aurora has a product called "Inflatable bottom spray" that claims it removes barnacles and the such. I've never tried it, but what products of theirs I have used always seem to do what they claim. You can probably also see what the manufacturer of your inflatable suggests.
Vinegar works great, but it has to soak for a while. Try 50% vinegar/50% water in a kiddie pool and soak for 12 hours. Should wipe clean with a rag.
No idea, but let me know if you try the acid, and how it works. I just use a plastic scraper on my inflatable.
The plastic scraper removed all the big pieces of shells but the remaining shell rings appear to be imbedded into the dinghy material. I bought the acid yesterday and will bravely test it this weekend.
Just got off the phone with the mfg tech service dept and they said to use WD-40. I'll let you know if that works. I have my doubts.
That's a new one for me. Let us know your results. The rest of us "barnacle assassins" would like to know!
your repair kit for the dink will have some of the material and glue for the seams. make up a small piece with a seam and soak it overnight in a pure acid solution. if there is no color issue or degredation of the glue, go for it. the acid will not take overnight to dissolve the barnicals. just use in a well ventilated place as the concentration of the acid from the pool store is pretty potent.
