Removing boat from trailer.
nph
I know several people have asked this question in the past. This weekend I had the "joy" of watching and helping with this not once but twice!
We were both pulling our boats for the season and brought to our house for blocking.
A friends 26' Searay and my 28' Regal. The Searay was scarry!!! big time. It was done by a professional.
The trailer was a roller trailer. I do not know if I would do this with a bunk trailer or if it would even work.
The 26' boat was done first. Fifteen cinders blocks for each boat plus wood. The boat was backed into postion, the stern straps removed and the winch cable loosened with about one foot of slack. The truck was pulled forward 10 feet then backed down gentle, and the brakes hit. The boat slide back one foot on the trailer. This was done until the boat was tetering on the trailer.
With someone pulling down on the bow of the boat, towers of cinder blocks then 2x6 and 1x6, are built under both corners of the stern.
Then the bow is let back up, and the stern sits firmly on the towers.
The trailers is then gently pulled forward, until just the bow is resting on the trailer. Another tower is built under the keel at the bow. SOmeone stands and bounces on the tounge of the trailer to wedge the last piece of wood under the keel. The trailer is then driven off from under the boat.
This took about 20 minutes. The Regal was done almost the same way, exceot the bow eye was in real bad shape, so instead on useing that to stop the boat when hitting the brakes, I truck was parked behind the boat, and the stren tie down eyes, were anchored to the truck and the trailer pulled about 2 feet forward, then the towers were built.
It was cool.
Scott
Personally, I would find another boat hauler. One with a hydraulic trailer that can lower your boat onto the wood only blocking without the acrobatics. Cinder blocks are not appropriate for that kind of load, they can crumble.
It is pretty tough to have a solid cinder block crumble. If a block is going to crumble, it will do it, as you are moving it around, or when you put a load on it. The boat yard here uses cinder blocks all of the time.
If I were doing this on my own, I might opt for wood over cinder blocks, but I went with what the hauler said. If money was not a question, I would buy boat stands and use them, better then wood or cinder blocks.
As far as the hydraulic trailer is concerned, it was a toss up, the hauler has a hydralic trailer, but putting the boat on a hydraulic trailer from the river in a 4-6 knot current, with out docks, was not going to work.
In the spring when they are launched, we will use the hydraulic trialer.
The post was not meant debate the best trailer to use, but to answer the many questions I have seen on this and other boards, of "How do I remove my boat from the trailer" Most people removing a boat from the trailer at home, and asking for advice do not have the hydrualic trailer.
For what its worth, my advice would be not to try the method you described if you were doing this yourself at home. As your first post states "this was done by a professional." If you've never done it before I can see lots of places for this to turn tragic or deadly in the blink of an eye.
Your talking about a cement block. A cinder block is not solid. In either case, I have never seen a yard around here use either. The recommended material is wood. What would happen to the boat if the block crumbled as you put weight on it using the method you describe above? If there were an accident with the use of cement/etc I would be willing to bet the insurance company may have something to say.
I have seen other methods of removing a boat from a trailer that take longer, but are much safer. IMHO, this is not one of them.
Guys, a concrete block, mounted w' the "holes vertically" is capable of supporting tremendious weight.
The pull and stomp is bad, but as far as support, no problem. If it was most of the structures would be gone by now.
lower Nose, place blocks w. wood top under stern, raise nose & lift boat off of bed as high as it will go.
Place block/wood under keel, lower trailer nose & remove.
I think I would call a local crane company to see what they would charge. Our local Marina does not have a travel lift that will work for the sail boats or larger house boats. The boaters contract with a crane operator and he will come to the lake and all will be pulled on that day.
Is it necessary to lift a boat off of a roller trailer for the winter? I'm curious since this will be our 1st winter with our boat/roller trailer. I was just going to lift the frame and put jack stands under it to relieve the weight off of the tires.
I would not worry about the crumble, however, I would worry about the stability of the stack.
Regardless of which worry, I would NOT use this method or hauler. I question his/her professional ability.
G
Geeze, my house's foundation is built with cinder blocks. Maybe I should have it all replaced with wood, since cinder blocks are prone to crumbling.
This sounds like a lot of work and danger, why not get a trailer and leave the boat on the trailer over the winter? Then you can put the boat in and take it out without hiring someone each year.
It is true that cement blocks can withstand great pressure as long as that force is evenly distributed across the block, much like in a home foundation where they are interleaved and the load is evenly distributed. It's also true that cement does not have great tensile strength and can break when not properly loaded. Cement has varying degrees of strength, but the block you buy at the local store are not of the stronger mix.
In any event, this advice came from a close friend that has over 30 years in the cement and boating business. Take it for what it's worth.
GripB - No it is not necessary to remove your boat from your trailer, you only have to remove the boat from the trailer when the trailer is not yours.
CaptainCrunch-a 28' boat with a 10' beam is not that easy to trailer and the 4-5 grand a trailer would cost buys me a lot of hauling back and forth once a year. I am looking for a good cheap used trailer but the tweo words good and cheap never seam to go together at least not in the boating world.
GColton - I am not worried about the stability of the stack, the stacks are on 3x3 pieces of plywood, the stack is 2 bolcks, wide by 2 blocks high, with a single block on the top center. Then each layer on the stack rotates direction. As for the Professionalism of the hauler. I trust him 100% I have known him for 10+ years, both in and out of the boating industry.
Again, I wouild not recommend someone try this on such a large size boat, withoiut some experince, But I have seen many "how do I remove my boat from the trailer" questions.
