Removing Intake Manifold
Scatman38
Hi: I just bought a 72 Starcraft with a Mercruiser 140hp 4cylinder. I took the carb of to rebuild and dropped a nut down the carb hole. I tried to get it with a magnet with no sucess. I need to remove the intake manifold now. Any suggestions or diagrams on this topic would be greatly appreciated.
Thanks, Scatman38
Don't know the motor, but I suspect removing the manifold wouldn't be too hard. But I am the lazy type so I would try the largest shop vac I could get my hands on first. You may just be able to suck the wayward nut out.
The vac is a great idea but remove the carb and eliminate any gas or you may have more excitement than you want.
Heh! heh! heh!
Brucie to the rescue!
drain any water before trying to remove the intake manifold.
Heh! heh! heh!
Thanks Guys for the suggestions, I tried the shop vac with no success. I did remove the intake without too much trouble. Found the nut in one of the cylinders, good thing I didn't fire it.
Scatman38
