Removing Side Panels
jimraab
I need to remove and replace the side panels on my Carver 2557 as the wood it rotting due to age. These are the side panels that are in the cockpit area where on the starboard side the shifter is located. Do you have any idea on how theses vinyl covered wood panels are typically fastened to the hull? If any of you ever had them replaced your feedback would be appreciated!
Thanks!
