Removing Vinyl
jimraab
I have an old boat that has stick on vinyl behind the Windshield which was placed over fiberglass. What type of solvent would I use to help melt the vinyl so that I could just scrape it off to prepare for the new surface?
Thank you in advance!
Use the heat gun like Don B said. You'll probably need some acetone to remove adhesive residue. Don't get it on the windshield if it's plastic, no problem if it's glass.
To remove adhesive residue,use 3m's adhesive solvent cleaner #08984. You can usually get this stuff at an auto body supply store. This stuff is like goo gone on steroids. I had some real sticky adhesive on the vinyl on my boat's interior and this stuff cleaned it off in seconds and did not damage the vinyl at all. You may need the heat gun to remove the vinyl and then use this solvent to remove the remaining adhesive.
