Renaming a boat
GilBry210
We are planning on putting a name on our boat this year. I have done some research on the process and have come to a roadblock.
I know that the previous owners had a name on the boat. It was sold to us on consignment by a local dealer, the name had been removed at some point. I think the dealer removed it because I remember seeing a picture of it online, in one shot you could see the name on the back. Unfortuately I did not think at the time to write down the name for re-naming purposes later. Now I am trying to find out where I can find it and am hving no luck.
Does anyone know where this info can be obtained. Thanks for the help.
Renaming a boat is frought with peril and should not be undertaken lightly. There is a very specific ritual to be done with lots of verbage and liquor and you can find it on the internet. Good luck....remember you do not want to piss off the boating gods.
DBH
Actually if you go to Boatsafe.com and look under Capt Pat's Ceremony For Renaming Your Boat it will all be there or just put in Capt Pats boat renaming in your search engine.
DBH
Depending on how long the old name was in place, on a clean surface you may be able to see a faint outline of the prior lettering in the right light/angle. Look closely. Trace it with a pencil or something removable. This may take a few hours (or days) depending on the mood of the gods.
For a substantial amount of money (plus travel expenses if you want me to be there in person) I will perform a boat name demon exorcism which should solve all of your problems!!
check to see if it was listed with SeaTow or BoatUS. The name would have been listed on their databases.
Mikie, it may come to that. Is coach ok or do you prefer first class?
This boat was used on a small local lake in Grapevine, Tx. I am not sure if it will even be registered with the USCG. I can't figure out how to research the database with SeaTow or BoatUS. I know my HIN but what is my "offical USCG number"?
What can I do if the name cannot be found?
If the boat was ever documented with the Coast Gyard, the # should be permanent somewhere inside the boat. Look in the bilge.
The boat is in the shop at the moment, I will look for the number as soon as it's out.
Is there any way of properly re-naming the boat if the old name is never discovered?
If your boat was documented with the CG, the number would be permanently afixed inside the hull at some accessible location, as was stated earlier. I doubt that the dealer would have removed the name and hailing port, since they are required if it's documented. If your boat has State numbers on the bow and a State title and registration, it probably was never documented. If it's State registered, the name is just your personal choice, change it whenever you want to whatever you like.
It is State registered and has the State numbers on the bow.
So if a boat has not been registered with the USCG then the name dose'nt count with the "God's"? Is there still a need to do the re-naming/naming ceremony if this is the case?
The Water Gods cover ALL boats, but their rituals are much different than the USCG. They're also far more flexible.
If YOU feel good about your ceremony, chances are they will too.
Do whatever makes you happy. If you just want to stick the new name on the stern and go on your way, that's fine. If you want to have a "christening" and make a party out of it, that's fine as well. The most important part is to enjoy your boat. Good luck.
If I can't find the name I think we will do a modified/anonymous denaming ceremony, something to please the God's. Then we'll follow up with a proper naming ceremony.
Thanks for all the advice.
This is definitely correct!
Look up Vigor Rules. Has the right way to please the gods. . .
