repair or replace 94 norcold
billybokay
I have a 1994 Norcold de560 that no longer works on dc. It is the largest fridge Norcold makes.The green light is on but it loses its cool when not hooked up to dock side or generator. It will be about $1100 to replace if I do it myself. If I try to find a repairman on Long Island to come to the boat, remove it from the cabinet and diagnose and repair it will probably cost as much as a new one.
On the other hand getting the old one out and the new one in will be a nice full day battle for me.
Is the dc side of the unit something an above average idiot like myself can repair.
I purchased a cd-rom for the repair and installation of almost every Norcold refrigerator model, for about $10.00. My unit got blasted by lightning. Because I had difficulty purchasing the parts, I finally hired a repairman to inspect it. To get the new unit through the cabin door, the new refrigerator would have to be disassembed and then it would be reassembled inside. The warranty on the new parts and the new refrigerator were the same. I elected to repair the old one. I replaced the electrical control system and the compresser/coil system.
If you look at the repair manual, you will find that the units are very easy to repair. Mine had three basid subassemblies. There is the sealed compressor/coil unit, the thermostat unit, and the electrical panel. Each of the three was a bolt in operation.
Yours may be different. I would look for the manual and then decide.
I just bought a new fridge today. The Norcold stopped working and was $700 for the cooling unit and I still had to put it in myself or hire someone to do it. New one was $1200. I chose to go with a regular 120 volt. I found an Avanti that will fit in the space. The No cold was 52 by 24 by 24. The Avanti is 49 x 20 x 24. Set it in the boat tonight and will trim it out in wood this weekend. Made a shelf to go on top to hold in place(can’t tip) and a piece of plywood on the floor which I drilled 1 inch holes in that the feet set in and screwed the plywood strip down to the floor. The Avanti was $240 at Brandsmart and has a light and is frost free. I have a 1500 watt inverter that runs it just fine although I know the frost free will use more power. I usually run the genset anyway but will use the inverter while under way and the engines are charging the house batteries. I can buy 5 new fridges for the priced of a nocold.
padfor-
Where did you get the Norcold repair cd? I would love to get one for future (maybe never?)reference.
If your interested in a used 2002 Norcold DE461 that works fine, I'll sell you mine for $400 if you pick it up. It backs up to my stateroom and the Norcold buzz (noise) drives me crazy. I've ordered a new Nova Kool unit which I should be getting within the next month. I made the same replacement on my last boat and really love the Nova Kool.
The NovaKool guy will give me a small trade-in value for the Norcold, but I'ld rather sell it to a happy home. It's located in Mystic, CT which may make a 2 hour drive from NY worth the trouble.
Tom
I did the same as seahawk but picked up a $125 fridge at lowes...fit's within 1/4 inch of the norcold I had.
Foot and Randy, I also bought the Avanti 110V unit to replace the no-cold (great minds think alike :-)! Three years and I am still very happy with it!
Delaware Jim
I replaced my full size Nc by myself. Cost about $1200 by the time it was done. NEVER AGAIN. todays technology (inverters) and a good cabinet maker combined with a standard reefer next time. I'll still be spending about the same money but about 1/2 of it goes in a local guy's pocket. And when that one fails I'll replace it for a lot less.
Norcolds don't make good anchors because they tend to float. If you take them apart the little trays are handy to hold nuts and bolts, old screws and stuff. Hmmmmh, I'm trying to think of something else they are good for. Nope, nothing else.
Wait, it's easy to take the coils free from the back, use duct tape (lots of it) and you can fasten the coils to the side so you can get it out of your cabin.
Mike, Palm Coast, FL
My DC side died two years ago. I bought as I remember a Summit which was about 1/4 the cost of a Norcold, had a bigger capasity and is much more quite then my old Norcold. Has no problem running off my inverter. My pop cans no longer freeze when I'm gone for more then a week. It's worked out great for me.
Faster now but still steady
My Norcold gave out last year,after 23 years..not bad. To get it out I had to disassemble it. Chris craft must have put it in then put the top on. I never used the DC ..I was afraid it would eat up my batteries. So I went to Sears and bought an apt. size refrigerator. Slipped it right in and trimmed it out. It actually has more room than the Norcold. Looks pretty good. Saved a ton of $$$$ to use on fixing something else.
Nova kool has no one in Ny according to their website. An inverter is no use to me accept for the fridge, so it is a wash, spend it on the fridge or on the inverter and a cheap fridge. I can't imagine a fridge designed for the home can withstand the conditions of the marine environment. How will a sears fridge handle 8 foot seas. Will the door fly open, will the wiring hold up.
I like the easy dc switch on my electric control panel so with a flip I can keep stuff cold, both when I am running, or while I decide to go to a restaurant for a few hours, and I can't leave the genny running cause people are eating dockside.
I am not a fan of norcold but I think I will regret getting a cheap home use fridge. I believe there is a dometic dealer near by,
so rather than try a repair, or buy more crap. I will see if I can fit their t85ac into my space. Seems close but just an 1/8 th of an inch might make it impossible. Cabinets can be rebuilt, but if the space is not there, its just not there.
You are right in some of the aspects. My fridge plugs right in to an outlet so wiring is not an issue. 8 foot seas?? Would never go out in those conditions. Actually I don't know how I would hold up in 8 foot seas.
Most fridges will plug in directly, but the internal wiring should be able to withstand the pounding and adverse conditions. Plus all of the inner workings should be able to take the extreme temperature swings, the constant motion and salt air conditions.
I am not a fan of 8 ft seas either, but we are pretty adventurous when it comes to vacationing. Last year we did a 450 mile trip, Lots of running in the ocean and you never know what you will encounter.
Bill:
Replaced the Nozrcold with A Tundra last Spring. The new one was a bit narrower and deeper. Minor trimming to set it in place. Love it. Quite and it actually keeps ice cream frozen. I've run it from a sinle 4D battery for 24 hours and still was able to start the engine.
Gene
I am going to a tundra/dometic dealer on monday. Decided to take the old unit out tomorrow to get exact inside measurements of cabinet. Thanks for the input. Tundra it is. t80 or t85, whatever it takes.
A while back I had a Norcold that did the same thing: worked on AC but not DC. I tore into it and found that a relay had failed. I couldn't find a replacement relay so I simply jumped some wires so that it was permanently on 12 volts. I figured that if I was plugged in then the battery charger would take care of it.
Rod
Rod
The smaller Norcolds are 12V only regardless of what the dealers tell you. They do suck some power on the hook. This year, I am shutting mine down when I go to bed and turn it on again in the morning. I figure if I don't open it in in 6-8 hours, it is not going to lose that much cold. We seldom stay out on the hook more than one night at a clip and if we do, we have the Honda 2000 to take up the slack
Today I purchased a vitofrigio.. or something like that. They are the company that made the fridge for tundra before tundra was bought by dometic. Unbelievable quiet and much more interior space than the same exterior demensioned nocold. Supposed to be much better quality technology and only about 150 dollars more than a no cold. Looks beautiful and clean and no worries about holding up to marine conditions.
