Repair shop problem
GilBry210
I recently had some fiberglass work done on my hull. When I went to pick the boat up I noticed my transom tie-downs were missing. They had never been put back on after the boat came off the lift. The boat was trailered around town to a few other places in this condition. I am worried that it may have been bouncing around and could have done some damage. Is this possible? What should I do now? Survey? This was done by the repair shop, are they responsible?
I have a '99 21 foot Crownline cuddy cabin on a dual axle Road Runner trailer. The roads were probably typical and bumpy.
lots of people cruising around with no straps and no damage. unless you've decorated with crystal, it should be fine.
what work did you have done?
Probably no damage, but get them put back on. It's definitely better to use the tiedowns when trailering.
The tie downs usually come into play if there is an accident or sudden stop ... if they traiered at low speed and for short distances ther probably was no damage.
Thanks for the advice. If there was some damage would'nt I also be able to see it? Maybe some small cracks or something.
It sounds as if you have a substantial trailer under a relatively light boat and that you are concerned about something that does not exist. Unless you can actually see something, then there is not anything to be concerned about. Do not try to make something out of nothing. Go and enjoy your boat.
If it had been bounced around enough to do damage it probably would no longer be on the trailer, I wouldn't worry about it.
If your worrying about cracks while trailering then you should also slow down for each wave you encounter.
