replace "bypass filter" with regular oil change?
booboo
I have volvo d9's. the engine has 2 oil filters and a "bypass" filter right next to the 2 main filters. I assume the bypass filter only receives oil flow if there is a problem with other 2???? In that sense, do I need to purchase and replace the bypass if I received no oil related alarms on the volvo evc since the last oil change 100 hours ago?
I'm not a diesel/volvo mechanic...but looking at the schematic, looks like there are a number of valves that regulate flow in the event of restriction or even cold/start-up conditions.
http://www.marinepartseurope.com/en/volvo-penta-explodedview-7746900-22-10109.aspx
One important factor, what time frame of your 100 hrs.
I change oil in my gas engine 4-5 times or more a year but I'm a little anal about getting in there and keeping a close eye on everything.
Think in terms of oil samples as well. They will tell you if you can run the oil longer or not.
so....change or no change. I used to change my oil every 50 hours on my crusaders and will likely start doing the same for the volvo's. How often should I be doing a change? The manual does not really address it.
Normally a by-pass filter is a very, very fine micron filter that gets a small amount of oil flowing to it at all times. For lack of a better term, it "polishes" your oil and helps extend it's life.
Volvo should be able to tell you how often it should be changed.
