Replacement Air Horn Compressor?
AustinPaul
As noted above--anyone have any ideas of a good place to get a new compressor? Here is a pic of the one in question set next to a 12oz can for scale. Looks totally generic. I set it on the dresser and snapped a quick pic, hence the pic in the background. :-)
Have you tried googling the part number?
Amazingly, there is nothing on the pump that I can locate. I was expecting at least a name of the manufacturer. That's why I'm thinking it's so generic.
It's for your basic twin air horns that are probably about 14" in length. I've seem some for about $100, but that seems excessive for such a basic item.
I located this one for about $33 and was thinking about calling them to ask about capacity. It says it is built for twin and triple horn applications.
http://www.buyautotruckaccessories.com/product.cfm/cf-bin/pn.wolo-high-output-air-horn-compressor/
The replacement compressor you have does work and works well. I have used it for several years.
Great feedback. Thanks sortie!
I also know why mine failed. It says right on the label "very important"-- must be oiled every (can't remember what the time span is). Mine is also mounted lower than the horns, so any water that gets in, runs right down the tube into the compressor. Water + not oiled = failure.
Anyway-- thanks again. A cheap fix!
Paul
Paul, Exactly what killed mine. Once you remmber to oil and keep water out,they do last. I had to repeat this twice before i fully grasped it.
Check any place that sellf accessories to long haul truckers.
Look in JC Whitney.
G
Bought mine at autozone. Part was identical. Threw the horn part away. 30 bucks
I got mine at harbor freight , too. It's hooked up to my SS air horn. works fine but a little noisy.
Can't tell if mine is noisy or not. The horns always blowin lol
