Replacing Carpet - Cleaning Up???
graxirena
Hi Guys,
I just ripped the carpet of off my 1988 1800xl stratos and of course, there is a BUNCH of glue and little piecs off carpet sticked to the floor. It is mostly glue...me next step will be cleaning and then making up my mind between painting it with just white gel coat or taking it to get the 'linex texture' i did in the back of my truck.
Now, what would be the best chemical to clean that up with and get rid of the glue?
Acetone? Tolulene? Maybe as mild as mineral spriits. Unless you know the exact glue, and can get a mfgr's recomendation, you just have to experiment.
what's the surface like where there are no cling-ons? how well finished, if at all?
you're going to need a respirator sooner than later and probably a grinder i'm thinking. i vote for sweat (...which chemical) although i wish you better luck with the solvents or whatever does the job.
most carpet adhesive is latex based and I don't think any solvent will just dissolve it. I usually use a very sharp scraper and scrape away. What's under the carpet? plywood? or fiberglass? If plywood, be careful not to gauge it with the scraper. If you were replacing the carpet, you wouldn't have to scrape it perfect as small bits of adhesive wouldn't matter. You can try an orbital type sander with 36 grit paper, but the glue might clog it up quickly.
Try an orange based solvent like "Goof-Off" or "Goo-Off". These are sold any larger sizes at flooring and janitorial supply houses. The orange based solvent will melt the glue loose and the clean up is a breeze. Try a small amount before you purchase a large amount.
I second the Goof off suggestion.
That should do an excellent job of removing most carpet adhesives.
