It's not an impossible task, one of the problems is the fuel getting all over the engine room.
Every hose you take off will have some fuel in it. Buy the 100 pack of 3m oil pads. Take your time, it will be a mess but if you take your time, try to keep it as clean as you can you will be alright.
On my boat they marked the length on each fuel line so when it's time for me change them out, I will have them all pre-made so swapping will be a bit easier.
Do you motors have priming pumps on them? If not the pump is a good idea, my Cats have them right over the secondary filter that is mounted on the motor.
Jonathan
