Replacing name decal help?
I had the heat gun with me as well but the wheel worked so well I didn't so a reason to use the it and struggle.
I compounded after and it came out real good.
The wheel does make yellow marks if you hit on gel in a spot without the decal for too long but compound and the sun takes them out.
Originally posted by Gregory S
Mark, my results with the wheels are similar to yours. Why people insist on doing this job the hard way is beyond me.
Probably because as others have mentioned they had a heat gun/hair drier and razor blade on hand, both of which can be used for many other projects, were not in a big hurry and didn't want to buy a tool they would only use once.
And yes I've used every method mentioned here at one time or another. And I agree that the wheel is probably the fastest and perhaps easiest (although Easy Off is pretty quick). But the other methods do work and work well for many people.
It's just another case of "to each his own".
Yeah, like the guy who keeps driving into the same pot hole every morning on his way to work.
Captain Bill, you're just not getting how important it is to use the only true method. To my shame, I also used to think 'It's just a decal, right? Who cares?'
I was blind, but now I see.
(roflmao)
I remove the old decal using the eraser wheel OMG what a breeze to use! So my question is aside from using compound and a buffer (which I have tried and it helped) how can I get rid of the shadow of the old name before I replace it. Although the new name is the same it will look totally different so it won't cover.
You can't remove the "shadow". The rest of the surrounding surface has been aging for years in the sun and weather while the surface under the decal has been protected and is in brand new condition.
The best you can do is to try to restore the surrounding area to try to match where the decal was. That may mean wet sanding, compounding, etc.
You'll have to sand up to a natural joint or the entire transom to avoid an obvious color and sheen change.
John, I doubt you'll ever see. Why does it upset you so much that those of us who have used a wheel, are happy with the results, and like to pass good information on? For someone who has never used one, you seem to have a lot of opinions about them.
You only have to swerve around a pot hole Greg. You don't have to by a new car just to miss it. :-)
Originally posted by mwwhit1
........... Heat guns have never done that for me. Always a ton of adhesive to get off after.
People often make the mistake of not using enough heat and not spreading the heat out over a large enough area. If you can pull the decal off with effort, you need a little more heat. Done correctly, most of the adhesive will come off with the decal. A little acetone on a rag followed by a soap and water wash and rinse will complete the job.
Is it safe if I plug my heat gun or drill+3M wheel into a portable Honda generator?
I was thinking of putting it in the bilge so I did not have to hear the noise. Good or bad idea?
Inquiring minds want to know.
Sometimes people pick some really weird swords to throw themselves on.
I remove the old decal using the eraser wheel OMG what a breeze to use!............
"OMG" ? What are you 12 years old?
I'm not upset at all, Greg. It isn't me who claims there's only one right way to remove a decal.
Just seems a strange (and somewhat funny) obsession. But I do aplologize for making fun of you. That was uncalled for.
If I decided to replace my boot stripe, 3" x 56', how many of these erasers should I expect to go through?
I would be guessing but 2 to 3 it really depends on the stripe and how stubborn it is. Again I used some off brand of the same thing it was half the price I have a customer with a body shop who loves them.
