RESULTS! Lewmar Freefall Windlass Problem
Well-known member
Posted - Feb 29 2012 : 19:38:54
I have been relatively happy with my Lewmar Freefall windlass with it's chain & rode combo gypsy with one exception....
Since new, once in a while the clutch delays engagement on retrieve.
The last few times we have used it, it just seems to spin and spin and the clutch takes minutes to engage...really it is now taking SEVERAL MINUTES of coaxing to engage.
I have found NOTHING in th edocumentation regarding any adjustment.
Am I alone in this issue?
Anyone have afix, adjustment or usage modification that we could try?
The delayed ngagement became an issue this weekend while I was replacing the cables on the boat lift and nearly drifted into the seawall.
Thanks in advance...
Is the an adjustment to the clutch? Usually at the top of the capstan, either a nut or a adjustment with a winch handle.
If the motor runs, then it has to be a loose clutch
I had similar issues with mine until I changed rodes. The boat came with a 1/2" 3-strand rode and I replaced it with a 9/16" 8-plait rode, which seemed to correct the problem for the most part. The documentation for my windlass stated it could take either size, but then another chart from Lewmar indicated that 9/16" was the correct size for my gypsy. It sometimes still slips, but if I wet the rode that seems to help, too. I have, at times due to loosening through vibration, had to tighten the gypsy from the top of the capstan, as Pascal suggests.
the problem is not that the rode slips, it's that the motor will spin and the gypsy simply does not engage.
Takes some time , used to be seconds
now it's minutes.
If this is your model ( horizontal shaft: Horizon 600/900 Freefall) , perhaps it's time to ..carefully...disassemble at least from the freefall housing to the gypsy to clean and relube and retighten the operating nut? Maybe check for an errant pawl spring too?
http://www.lewmar.com/assets/img/dataset/Manual-Horizon_free_600-900.pdf (pfd p. 18-19)
Pfd. P. 22 shows the line and chain specs for the different optional gypsies, so you might try to confirm you have the proper match.
But it would certainly be a good move to contact Lewmar for their advice as Capt Bill suggested. (203)458-6200 in Guilford, CT)
Is it vertical? Horizontal? What model? If you are not going to contact Lewmar at least give us a clue. :-)
Hi and THANKS !
It is the Freefall 600/900 horizontal windlass.
I can confirm that we are using the correct BBB spec chain and rode.
There has always been something of a delay from th etime the motor begins to spin and the time the clutch engages.
Usually just a few seconds, but the time to engagement has become erratic lately, off and on.
By the way, it ALWAYS releases as designed.
Has to be the clutch, again start by tightening it up
If it was electrical if motor related, the motor wouldn't turn
If it was the wrong chain or rode, you'd see it slip on the gipsy
If you hear the motor turn and the gypsy takes a while to start, it s the ckutch
Originally posted by RWS
Hi and THANKS !
Again a simple call to Lewmar will probably answer this.
If it was just loose I don't understand why the drive cone would slip for all that time then magically tighten down on the wildcat and not slip again the whole rest of the time the anchor is coming up. This is what is happening, correct?
But there is a part in there called a "drive nut"(PN112)I wonder if that is the issue. It looks on the diagram that if that is loose the drive cone could slip. But it is strange that it could tighten up on it's own and then go loose again while sitting still. But then again, it's a boat so anything is possible. :-)
You have checked to see that neither the "set screw" (PN125) nor the "socket screw" (PN117) are loose?
Remove the cover I am pointing to (bolt in center and allen screw directly below). Find the "operating nut" and hand tightened back against the spool. The manual does not mention this.
tried this a few years ago (made sense) and found it to be tight but will do so again today and report back.
If I have to dismantle it do you think I should remove it?
Time/effort in removal vs. time /frustration doing it right there and dropping a small screw overboard.....
Quick and easy procedure, no need to remove it and then have to re-bed it.
O.K.
Here is the result ...
The cover is attached with the 10mm hex head bolt at the top and the allen head screw at the bottom.
I found the top bolt to be tight, the bottom allen screw was frozen, but I was finally able to remove it.
I removed the cover and attempted to tighten up the offset cam nut. It was tight and I could not tighten it up any further, even with an offset pliers.
Inside the cover is a spring loaded loacking prawl.
I found some nice clean green grase residue inside the cover, but little lubricant.
I then put a liberal coating of lubriplate on the cam and a good coating of antisieze on the allen screw at the base.
I also sprayed the spring loaded prawl with some WD 40 prior to the Lubriplate.
After putting it all back together I was sure to tighten up both fasteners securely.
I tested the windlass after reassembling and it seems to be working as new.
The only question is - was the lube the solution, or was it a function of tightening up that allen screw at the base?
I hope this can help someone else.
Here are some photos with the cover removed.
I wuld never have known to remove the cover without those helpful RO's from BoaterEd !
