Rinker opinions
lsilver
Hi,
Looking at a 99 rinker fiesta vee 330, with merc twin 5.7 efi fwc Bravo III out drives.
looks ok on the surface, wanted some feedback as to overall likes and dislikes of the rinker brand/ this model
thanks,
Larry
I have a Rinker and I like it. Depends on your boating style but its a good boat.
Others will have much more specific info... I just have a couple of things:
I've known of several Rinkers (even newer ones) with leaking hull to deck joints in our area, so make sure to have that checked by your surveyor.
Make sure those Bravo III outdrives are in good shape, you probably know of corrosion issues.
Good luck.
I have a 330 Fiesta Vee, 2000 model built in 1999. I love it and have not had any problems. AI added prop zincs to handle the corrosion issues. I also have Mercathodes that came as standard equipment.
I have a '91. Bought it in 2000. It has been a good solid boat - they surveyor I hired was very impressed with the construction. I've hit a couple of good sized semi-submerged logs (very common where I boat) at full throttle with no damage to the hull. It is a bit spartan in the decor but the admiral has added some decorating to spruce it up. I don't know much about the newer models but based on my experience I would recommend them.
Cheers, John
padfor,
which engine do you have with yours? how is the does it handle? top speed? cruising speed?
I have a 2002 31 rinker which is the 33, had the boat for 5 years and did alot of travel to block island south jersey north on hudson, no problems and great mid range boat. I have 5.0 mercs with bravo 3 drives, I cruise at 28 to 30 and top out at 41 MPH. I burn about 17 to 18 gal. an hour at cruise. Did add extra cone zinc and mercathodes was on boat, did add buttons on transom around drives. No leaks. First one in my marina to have 31 now there are 4 other people with the same boat who upgraded. good luck
"Rinker opinions"
I looked at them 8 or so years ago (new) liked them and thought they offered a great value. I know some people that own them, and they love their Rinker’s. I believe the company changed hands a few years ago. The company was a family business, my brother in-law was friends with on of the owners, when I asked him about the company (he owns a boat shop), he pretty much endorsed them as a stand up company.
All manufactures have their F-ups, so Ernesto’s post should be something you should look into.
Happy hunting.
I'm on my second Rinker and very happy with it. Yes, there was an issue with leaky hull to deck joint on certain model years and I would have a surveyor check this carefully. Well made boat, solid fiberglass and very thick. Rinker customer service is tops. I've personally spoke with Randy Rinker several times when I called customer service. you can check out rinkerboatowners dot com for more info.
We had a 2005 Fv250. Good value for what you get. No real problems.
Niles
This is my 10th season and still going strong. Good value ,fit and finish is ok but not top of the line.
Excellent customer service; you don't need to "know" Randy Rinker to get that great service!
I've had mine for 4 years now and while I can't complain overall I wouldn't buy another one. Lost my interest in express cruisers and selling a used one around here is next to impossible. Most people have never heard of them, and those that do say they're crap. Of course they've never owned one but it doesn't help to have that kind of reputation.
Rinker is a popular boat in the north east area. Trading my boat for a larger boat and broker has possible buyer for my Rinker already.
You'll have to deal with the occasional "oh you bought a rinky-dink boat eh?"...
The same year I bought a Regal a friend of mine bought a similiar size Rinker. I was on his boat quite often. I liked the boat. Not the same quality as a Regal, but it was a good boat considering the cost difference. I wouldn't hesitate buying one based on his. He never had an issue with it.
Have a friend with a 99, 330. Some things not designed very well. He has to pull the batteries out to change the oil in the genset. The one piece electric hatch with the transom seat can be difficult to work around. Doesn't open up far enough to suit me and makes maitenance difficult. Also, cheap plastic striners on the raw water side of the AC. It's the things you don't see when you look at the boat.
In response, mine has always been in fresh water. The engines are 5.7 liter, 260 hp EFI. Top speed is about 37 with clean props. Stays on plane about 20. Handles very well. We mostly run leisurely around 1,500 rpm and sometimes just float and swim.
Great boat for company. I would sell it to get a bigger boat, but not otherwise.
I am on the fence,
between this boat and waiting on finding a sea ray 330 in my price range
I really like the interior of this boat,better than the sea rays but wish it had 5.7 mag, or 7.4
the deck on the sea ray seems to have more fit and finish to it
and am not really sure if the 5.7 is enough to pull the boat out of the water well.
also not sure about the bravo iii drives and corrosion control. this boat has the old style mercathode.
