RubRail got rubbed
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
Since I'm the only one out of all my friends and family that can back the trailer down the ramp, I usually have to let my wife or a friend handle the boat at the ramp.
Well, SOMEONE (Jimmy, I won't embarass you here by naming names) rubbed up against the dock a little harder than they should have, and the rub rail (vinyl) got sort of , well, rubbed. What's the best method for making is smooth again? A little sandpaper?
Sandpaper will abrade the surface and dirt will get in there and make it look worse. Try a heat gun and smooth it down if you must....best advice though?....Leave it, that's what a rubrail is for.
In time, you can replace the entire vinyl insert. Very easy to do.
I'm with Mike. Just go out and enjoy your boat! Now if your glecoat had gotten gouged, that is a different thing!
I like to rub my rubrail
Doug
Yup, leave it. My Chap 265ssi had a SS rubrail. Awesome!
Doug
Before I rub anything I have the Jergens handy and some Kleenex.. whoops sorry...[:-eyebrows]
I would let it, just in case " Jimmy " comes along again, and you can point out his docking abilities !
Try this in an inconspicuous spot first. Get a little acetone or MEK (methyl ethyl ketone) and gently paint it on the bruised portion. It will liquify the rubrail material allowing you to smooth it out. After drying the bruise will be substantially less visible.
This assumes that the rubrail material is thermoplastic--if it is thermoset, it will just swell--in that case the above technique won't work.
Sandpaper works just fine to remove unslightly rub rail stains from dock pilings etc. Start with a heavier grain, finish off with a fine grain. For light stains, a very fine grain sandpaper is all that is necessary.
I sand mine once a month or so, it only takes a few minutes to make the rub rail look brand new again.
I use WD40 on my rubrail once a year. It brings back the shine and helps to keep it from getting that dry look.
Originally posted by solar
Or use a plane to take it down.
I would think crashing a plane into his rub rail would be a bit much.....:D
Fun to watch though...
You can hang old tires all around the boat to protect it. That looks pretty classy.
A picture would help to determine weather it should be left alone or cleaned up.
