I found an interesting solution last week to a nagging problem, leaking rudder shaft logs. ours are located in a very difficult space to access so tightening them is a real PITA. with some age and corrosion where the shaft meets the packing the problem becomes worse as the movement of the shaft wants to remove the smooth face of the packing. Tides Marine has a drop in preplacement called a Type J rudder bearing. it replaces the larger packing nut with a dripless lip seal as many of us already have on the prop shaft. same seal and it resolves the issue of adjusting the gland nuts/lock nuts in a really tough spot to reach.
