Two years in a row my boat overheated on its first spring outing and both times the impeller ribs had torn off.I have a 1994 454 with a B2 and full FWC.In Dec. I flush the raw water side of the motor putting cuffs on the outdrive and running antifreeze from an elevated containter (made for winterizing outboards) thru the motor while I fog the carb.My mechanic says don't run the 454 on cuffs.How else can I winterize or flush (the motor is in brackish water)?Can I run the motor in a large pail with antifreeze?Should I put a water intake somewhere in the system to feed the antifreeze? Should I just drain the raw water side of the system,but wouldn't water be left in the raw water pump?
