Running A/C while Not Onboard
C team
I got into a little argument with someone over running my A/C while not onboard. I know anything is possible and could happen, but if you use reinforced hoses and double clamp all connections, I don't see the problem. I do not close all my seacocks every time I leave and I'm sure my 1.5" engine hoses would fill the boat faster than my A/C pump. Heck, if you wanted to be entirely save about it, you would tighten down your shaft logs, close all seacocks, disconnect your shore power, and drain your fuel.
Sorry, just venting!
You are going to get many different answers about this.
If you have inspected your hoses and know that they are sound, no chaffing, the clamps are good, the seacocks good, then you should be able to sleep at night.
Others, like Bob ask why you need to run it.
I've run mine during the day when it is extremely hot out to maintain cool in the boat.
Let's see who else chimes in on this one.
Jonathan
Running the A/C when not using it sounds wasteful but heck it's your money?
Craig, I am with you......seacocks remain open and both air / heat units remain active during the week......although prudence dictates frequents checks on all fittings.........one could be extreme and state the only effective way around everything is to put it on the travel lift after each weekend !!!!.....but then a strap could break and it might still fall over .....
Originally posted by blouderback
Why would you want to run the A/C when not on board?
When it starts to get very hot during the summer, I have a programmable thermostat that turns my air on by Thursday. This way, when I get down on Friday, the boat is cool.
For humidity. I don't run A/C per se, but SMX controls have an dehumidifying mode that runs the system on an adjustable schedule to keep humidity at bay in the cabin.
I run the "HU" mode with the default settnigs in mild temps, and bump up the schedule during the rainy and hot seasons.
True, or you can be on the hard and an earthquake comes along and knocks your boat over...
I don't have A/C onboard, but I often keep a hatch locked in the "cracked open" position to keep fresh air circulating throughout the cabin. I never leave the power plugged in when I leave my boat after the weekend.
We have a new guy with a 1980's Bayliner in the marina who leaves his boat plugged in. Every time his refrig cycles on, the entire shed has power problems that we have never had before. We are trying to convince him to not leave his power plugged in until he gets things fixed, but he is in denial!
I too run mine in Dehumidify mode when the weather gets hot....
When it gets real hot i leave her in a/c mode... ( Set to a reasonable temp )
Ur salon refrigerator will thank you for for this ....
I am like SLW, I suppose I could go purchase a dehumidifier instead but I am down in my engine compartment almost every time I use it because I like to look around. There is always something to clean...
nearly all boats in south florida run the AC 24/7/365... benefits ? boat stays cooler and less humid... it's not just nice when you get on board but heat and humidity aren't that good for the interior, electronics, appliances, etc...
AC pumps dont' put out much pressure so the risk of a hose bursting are near zilch. heck... even if a clamp fails, you still have a second one... and then even if both fail you still have to pull real hard on the hose and often cut it to get it off the barb fitting anyway...
then even if something fails, pumps on the typical boat are still much smaller than your bilge pumps... and then when the AC unit shuts down after water flow stops, the pump will stop so you're left with very little water coming in the boat, even if the failure happened below WL.
routine inspections of the system are enough to prevent disasters...
Liz, a single fridge can't affect other boats around unless the power supply to the dock has a serious issue... the marina needs to fix it. there is no way for a fridge to pull enough amps to cause issues...
the risk with smaller boats is obvioulsy galvanic corrosions attacking the drives... but if everything is in order, that shoudln't be a problem either. and if it is, routine inspection of your zincs will tell you before anythign happens...
if you suspect the new guy has electrical issues, inspect your zincs !
In the north, the HU mode is MORE effective at controlling humidity than the AC, because it runs on a schedule instead of by temp, so it can handle damp COOL days too.
It's too bad that so few people even know that their units even have the feature though. Unless you have the remote control,(which has a specific button) you have to read the manual to even know it's there.
My zincs are in great shape 'cause my boat sits on an air-dock when I'm not there....
why would there only be a problem since this guy moved in and not before? I've been in the same slip for 8 yrs w/o any problems until he moved in and plugged in. Every one thinks it is his boat/wiring......
I leave the boat with the units in dehumidification mode.
Craig not enough info. Would that "someone" be marina management that supplies free electricity? Or are you metered? Is that "someone" a member of the yacht club that shares in the electrical expenses? If you're metered and the marina approves, don't worry what the neighbors say or think. And of course check all fittings, pumps, hoses, ect......
Whatever happens, Keep Your Cool. :-)
possible... but "everyone thinks" doens't mean it's true :-)
if there was a short on his boat, the breakers will pop. if his fridge woudl suddenly pull high amps, the breakers shoudl pop. it really sounds to me like the issue is with the dock wiring. what kind of problem anyway ?
I leave the AC on 82 during the week, auto programmed to drop down to 78 on Friday morning, so it's nice and cool when I get to the boat Friday evening.
I run my a/c constantly here. When I leave the boat I set the thrmostat higher. The boat stays relatively cool but not comfortable when not onboard. I have two a/c and two pumps and the seacocks are never closed. In the winter (like there is really a winter here) I only run the salon a/c in HU mode when not aboard. I go to the boat no less than every other day and just putter around checking various things. Once a week I clean the a/c strainers and place bomine tablets in them. I operate all seacocks once a month usually around the 1st or 2nd of the month. I spray all my bonding conncetions, rudder ports, steering assembly, raw water strainer thumbscrews, stuffing boxes nuts, electrical panal, helm electrical connections, electronics connections, etc with anti-corrosion spray about every 6 months. To keep such a schedule I have a small pocket notebook I use for frequent maintenance items. I do not clutter my maintenance log with these things.
