- May 7, 2007
- 26203
- 207
I have twin 1994 mercruiser 5.7 FWC motors with alpha 1 gen II drives. The engines are set up with a thru-hull intake for each motor. The intake on the drive is capped off (drive cools it's self).
Just put the boat in last weekend for the season. My starboard engine runs around 175В°F at an idle. when I run the boat, it runs great at 160В°F (they both do). I changed the impeller on the engine mounted water pumps last year. Where should I start? Should I do an impeller, can it be the pump is going?
in advance.
in advance.
