Sanitizing fresh water system
Dauphan
I know someone who has a 1949 North Sea Trawler with two 600 gallon steel water tanks. These tanks probably has not been looked at since the boat was built. Unfortunately, it also has a high bacteria population. I'm trying to help them reduce their bioburden and I'm hoping someone out there could also give some guidance.
My first thought was to 'shock' the tanks by adding either bleach or a peracedic acid solution. Problem is the tank and lines are steel and these solutions are corrosive. There is also no way to recirculate the solution through the lines. It also may not completely remove the biofilm without rinsing first with a surfactant.
Another option would be to put a bank of filters at the point of use. A 0.2 micrometer filter effectively provides a sterile product. Add a 1 micron and a 10 micron filter to get rid of junk. However, the system water pump may not be sufficient to push water through these filters and still have any usable flow out the end.
Ideally of course they would pull the tanks, upgrade the water distribution system, and install a water maker. The price on that is beyond any foreseeable means however.
Can anyone provide any recommendations on how best to provide a very low cost and effective method to provide safe potable water for the short to intermediate terms?
Have a look at this "sticky" thread in the Sanitation forum. Maybe you would find this method acceptable.
--edit--
Note that there are several products out at this time that are labeled as "bleach", but they are not all the same. Be sure that the un-scented household bleach that you use contains straight sodium hypochlorite as the active ingredient.
Easy...Yup...Pretty...Not by a long shot.
You can recirc the water by separating the tanks from the rest of the system. In that the system itself is not pressurized, you could drill a hole in the top of the tank and insert a line into that hole. Connect the exit line from the tank to a pump. Connect the line going to the hole in the top of the tank to the exit side of the pump. You can place filters in the line to gather the "funk" that has collected in the tanks for almost 60 years. It would be almost like a fuel polishing system for the water tanks. A local college or if you have contacts at a military base should be able to test water samples over time. I'm no engineer, but I would think a solution of CLR in the water tanks would be of some help if you are worried about corrosion that could be caused by a more caustic cleaning solution.
For the faucet side of the system, you could do the same thing by bypassing the 12 volt pump and hooking up hoses to the thru hull drains and / or shower sump (depending on the plumbing of the gray water). Place a pump between the lines coming out of the thru hulls and the lines feeding the the faucets. You may need to place a holding tank in the loop to compensate for the power of the pump. Replace the 12V pump.
You could combine the two, but I do not know if the system could keep up with itself.
Just an idea. OK, Just a cheap idea.
HTH
Good luck.
I would suggest a two step method using two different chemicals. You can purchase these chemicals at a janitorial or restaurant supply dealer. First purchase a descaler chemical like what restaurants use to flush their ice machines to keep the water lines free of bio-film and lime deposits. Fill both tanks with a diluted mixture of the descaler to loosen the filth in the tanks. This will be easy if the boat is in the water, just fill the tanks and take the boat for about an 15 minute cruise to slosh the solution through the tanks. Pump out the solution thru the water lines such as shower, sinks etc. Be sure to use every line to insure the solution passes thru all the lines. Fill and rinse the tanks with water, empty and then refill the tanks with a quaternary sanitizer mixed with water to insure complete sanitation. The quaternary sanitizer chemicals commonly are diluted about 1/4 oz. to a gallon of water so you would need about 2-3 gallons to insure complete disinfection.
Here is the type of quaternary sanitizer would should be able to find very easily :http://www.buckeyeinternational.com/products/foodservice/saniq/pdf/Sani-Q_2-08.pdf
This method is used regular in bottling and dairy facilities to sanitize tanks and lines. Both products are non-corrosive and easy to use. You can purchase a simple little test kit at the supply house to verify that the water is sanitized to provide peace of mind.
Neal's idea is probably better than mine. Mine has him hands down if you want to go for Rube Goldberg effect.
Thank you for your quick responses. I forgot about quats. I frequently use phenolics at work but hadn't considered them for this application. I know the local sales rep for one of the major suppliers and I can ask her about quats. It turns out the person who owns the boat already got a bunch of bleach, so we are going to try Vic's method first. Hopefully with a minimum of exposure time and a lot of rinsing (at least 3X rather than the 1X Vic recommended), we can minimize additional corrosion due to the bleach. The owner is going to replace the pump so that part won't be a problem anymore. Thanks again.
I hope we helped. Let us know what you ended up doing, and what your results were. We would love to hear of the results. Good luck!
Neal, I really like your solution to the problem. Is there an online site which will sell these to me directly? Or will a janitorial supply house sell directly to a consumer?
If you can locate a janitorial supply house or a restaurant supply dealer that has a showroom or is open to the public, you can normally purchase these items through such a dealer. The descaler and quat are commonly used in commercial ice machines to remove lime deposits in water lines and flush with the food-grade quat to sanitize. If you can print the PDF file in my post, most dealers can match the same chemical in another brand.
Short update. We flushed the fresh water tanks according to the recommendation in the above link with bleach. We also rinsed two full tank full of water through the system. Bioburden tests indicated zero aerobic bacteria but we did not measure total organic carbon or conductivity. On a side note, our hot water heater failed and started leaking diesel and water. Probably because the bleach solvated some of the corrosion enough to make a couple joint leak. We'll be going in there again to find out exactly what the damage is. Even so, the sanitization process worked well. Let me know what folks find out about the quaternary ammonia sanitizer. Thanks for your help.
