sank the darn thing
rowong
had a great summer . on the way to lift the boat tore the keel off the darn thing on a un marked rock. went down in 2 min. marina guys came and got it.
3 .0l mercruiser alpha 1 , 1995 .16 '
my question to fix and keep or scrap
what kind of boat ? how bad is the damage ? salt or fresh ? if fresh, it's not too bad... if salt, the mechanic need to flush the engine immediately if your'e going to save it...
fresh water is better... less corrosion issues. if they can flush the engine and if the fiberglass damage isnt't too bad, it shoudl be fixable... unless you prefer to have the insurance total it...
If you have it on a trailer and can get to some facilities.....you can open up that engine and flush with the Garden hose followed by the oil. Change out the filters etc.
The outdrive is a little more trouble, but its do-able. Get all the water out fast though.
The keel is another kind of problem. Those little light boats are fixable.
Go down to "Marine Detailing and Fabrication" forum and post that part.
I had a 29' Atlas that had a 1" Bottom.
I was a lttle too close to the beach and hit an un-marked rock going almost 30Mph.
That boat vaulted into the air, turned sideways and went off to the left with such a lurch I would have been ejected if there hadn't been a good bulhead at my shoulder.
I nearly lost the boys too.
All I suffered was a terribly deep gouge about two feet long. Down to the Fibers.
I paid a guy to fix that.
The lesson is: ..buy a thicker boat. That way you dont worry about little things like Rocks.
