Sat antenna update (long)
mikebrookins
The following is an update on the Sat TV band issue I received via email from an unnamed marine electronics company. I have deleted any reference to their company. This is from a email newsletter and is not copyrighted. It is an open email so it is ok to reproduce on boaterEd.
"There has been some news in the world of HDTV for the marine industry. Here is what I know thus far. At this time, DirecTv has plans to move all of their HD programming from one satellite to another by early 2009. While this in itself is not a big deal, what is concerning is that this change will affect those in the stabilized antenna arena as the move will involve changing the frequency that the HD programming is transmitted on. Currently, DirecTV broadcasts their HD programming on the KU frequency band. When the move occurs, the HD programming will be on the KA band. In basic terms, this means that all satellite TV antennas currently in use for HD purposes will most certainly no longer receive HD signals. This is simply because the LNB (the device in the center of the parabolic dish that receives the signal) is set to receive KU frequencies and not KA. In addition there is no LNB out that will be able to receive both KU and KA. In addition, since the KA band is higher in frequency, there are inherently more difficult issues with tracking that signal and in most cases, a larger antenna may be required.
What I have briefly outlined above affects ALL marine stabilized antennas and is not just limited to one brand. Most manufacturers are working on a fix for this looming issue but at this time, there is not one present. One apparent solution might be to have two separate satellite antennas, one for receiving standard definition programming and one for receiving HD programming. All of the above has nothing to do with the upcoming switch to digitally broadcasted signals by the local TV networks in 2009. This solely has to do with DirecTV and how they plan to realign their HD package.
I have not confirmed yet whether this issue affecting DirecTV customers will also affect those who subscribe to Dish Network. I am working on the details and as soon as I can confirm one way or another with respect to Dish, I will advise.
My suggestion at this point for those considering adding satellite TV to their boats is to certainly move forward with that plan but to hold off with any plans of incorporating any HD capability to their systems. This has always been my suggestion as if one does not have a large TV that can really take advantage of the HD signal, I have not felt that the additional expense is worth the return on investment."
Yup, Direct tv is going to do this move as far as I know and it is giving the stabilized antenna manufactors nightmares. I have been told that they do not except a fix for this any time soon. It seems Dish is NOT following this move so it might be that Dish is going to be the provider of choice the mobil market. Ps I have had HD on the boat for the past 3 years and love it.
Cor
sabrejocky is correct. Dish Network has not, and is not planning, on changing the band that HD is broadcast on. They did just switch to MPEG 4 (from MPEG 2), but that was just a receiver issue. When it comes to HD, Direct had a slight advantage over Dish with the fact that their satellites are easier to pick up in far Eastern areas (Bahamas, etc.). However, that only really applies to SD (Standard Definition channels). Most of Dish's HD channels are on the old Voom satellite (Rainbow One) at 61.5, which is very much a Southern sat.
Take it from an HD junky who's had Sat on his boat for 4 years now....if you want HD, go with Dish Network. It will take the antenna folks a few years to catch up to Direct's crazy changes.
Want more info on the two? http://www.satelliteguys.us is a good forum to get information.
I know this is off topic, but it seems like you guys follow the satellite programming pretty close.....what about the FTA or Free To Air receivers...any of you guys have any experience with them? And just what do you get
I haven't messed with them, but there's a bunch of information on satelliteguys.us
FTA's are only for those who like to tinker. They are not very reliable and go down every few days or weeks and you have to wait until a new update comes out to reprogram the receiver. Don’t know if they have in motion capabilities either. I know on my old Datron 4000 system I have to have a low speed data port 9 pin receiver(Sony) for the system to tract in motion but it works very well with Direct TV.
After doing a litle looking it appears the FTA's would be kinda like going back to the BUD (Big Ugly Dish) days...see whats on this satellite then see whats on the other....I agree with you Randy...however the prices of the rcvrs are attractive....
This might be a dumb question but I'm new to marine-based satellite systems. Do you have to use the big antenna like the one they use for home installations or is there a smaller antenna for marine use that doesn't look too bad? If there is a smaller version any ideas where to find one?
Bryan
