Satellite Radio
MarkMuck
I would really like to have satelite radio in the boat. My clarion unit is not set up for it. I would have to get a new radio that is compatable with my dashboard remote.
We spend a lot of time in our covered dock.
The dock has a flat metal roof which is at least 20 feet high. I'm wondering if it would work at the dock. Anyone have any experience with this...? Thanks.
Mark
My wifes sat. radio loses its signal when she pulls in the garage. There are chargers available for them that plug into a cig. outlet that allow you to play them over your existing radio wirelessly. You tune the radio to an unused station and set your sat. radio receiver to broadcast at that channel. Works well.
Mark, I doubt that it would work under a metal roof. We have it on our boat and when we go under a bridge we will loose the signal. Do you have a GPS signal in you slip? It might work if you do.
I just installed sirius radio on my boat. My radio has an aux. input so I bought a cable to go from the sirius to fm/am radio. I also bought a new antenna from ebay and installed that on the boat. If you don't have an aux. input on your existing radio then you can tune in by finding a unused fm frequency. As far as getting reception under a covered boat dock, if the antenna is on the boat, you won't get reception.
if your existing stereo doens't have an aux input, you can use a K7 adapter (if it's that old...) or the FM transmitter. FM doesnt always work very well although now sirius offers a special antenna to install near your radio's antenna to improve the FM link
about reception under a covered dock, sirius does have some ground based Xmitters to improve sat reception when blocked by bridge, roofs, building. Not sure if they have ground coverage in St Louis but worth checking.
My boat is in a covered slip with a metal awning also. I had too many issues with getting the antenna to work so I bought the stilleto 2 which allows me to stream through my wireless internet connection when under cover. my head unit is not sirius ready either so I installed a sattelite marine antenna on my radar arch and connect the device to the aux input on the back of the head unit. Everything works great!
My little gem is a Delphi RoadyXt which cost nada and the XM monthly fee is around $12.
This comes with me from my car to the boat and just plugs into a cradle that XM provides. It transmits on a pre-selected freq. to all FM receivers, selected to the same freq., one in the aft cabin, one in the salon and one on the flybridge. It sounds like I have surround sound throughout the boat.
The little receiver stays out of sight as it is normally selected to only one program (Watercolours), the channel never gets changed. If changing channels is a requirement then it will need to view the remote.
The antenna just looks out of the glass windows but can also see thru' canvas.
In my cars I loose signal when I go under a tree.
G
