Satellite T.V. question ?
Yup, had one, sold it. Works in one axis only, albeit the most important axis. With your boat, wakes in the marina as well as at anchor will cause a loss of signal. Also, not great underway. Oh and did I mention, it's fugly to have a dish like that on a boat!
On bigger boats, like Pascal's you can get away with it since they can be mounted in out of the way places. On yours it will look very out of place. Also you should remove it when underway as it's a huge wind catcher.
yep, it's the former Follow Me TV. Rommer is right, it works real well but the dish isn't pretty :-) on an express you want to set it up to be removable... i wish they'd use the same system and simple compass but in a fiberglass dome. that woudl be ideal...
KVH and Kings have dropped in prices and maybe a better option on a boat like yours. still twice the price but looks better
The only time we use the TV is at the dock, and 90% of the time it's the kids. I just use a standard satellite dish mounted to a 2x10 about 24" in length with rubber feet. Total cost was around $60.
Sits on the chartable up on the flybridge and shoots through the eisenglass just fine. The board lines up with the side of the helm station and I installed a quick disconnect up there as well. It's out of sight and quickly removable when we get underway, but also quickly set-up when we get back.
When were on vacation, taking a trip somewhere or at on the hook we are too busy for the TV. The kids may bring a few DVD's to watch, but we don't miss it much. I would love to get a KVH or the like, but it's just not that important to us so the method we use works just fine.
Just food for thought...
I've had the AzTrax for about 3 years. Works great in the slip or at anchor. Looks better than the Track-It (Follow-Me) and is easily stowed when under way (it mounts to standard Magma grill accessories, so I have mine configured for a rod holder). Also, it comes with the dish which is white, and again helps the looks. I think they're still selling them:
http://www.mssat.com/
They used be be carried by the big stores, but now I think Bill just sells mail order. I've met him. Nice guy.
Funny how both AzTrax and Track-it are both made by MD companies.
I'm a big fan and user of KVH products. It is a case of getting what you pay for. Mine tracks while in motion and works great. It looks good as well. I also use the TracPhone 252 after learning a bad lesson about Globalstar with a Wavecall 3000 it was a total waste of money buying the WaveCall. The TracPhone 252 from KVH has never let me down where the Globalstar phone only worked about 20 minutes out of every hour due to satellite and network problems, I spoke with a KVH tech and they told me they were approached by Globalstar to build a marine sat-phone and they refused because they knew the sat-network had serious problems. It seems to me they only align themselves with good partners to keep their excellent reputation in tact.
Regards Bill
DD,
On your 37 SR, the new smaller KVH (12" dome, I think)would work really well and not look out of place. A larger KVH or an open dish like the "Track it" would not look cool. Plus, everytime another boat goes by your anchorage do you want to see a blank screen?
Like BillyIII says, you get what you pay for and KVH is the absolute best in the industry. Great customer support and the ability to update as time passes.
Question. I was just informed with KVH, you can get direct TV but no HD channels. I was surprised to hear that. Is that in fact the case? I do have HD TVs on da boat.
I got an upgrade to my KVH which allows me to get the high def. Basically, they added a small box which tells the Sat which bird to aim at. There are 3, maybe even 5 satellites, for DIRECTV. You program it, so that it knows to aim at the different satellites for high def v regular.
Although when I contracted the work I asked if it would get all the high def channels. I told the contractor that DIRECTV has added almost 100 channels. The contractor either ignored me or did not understand. So I get the "original" high def channels. 70-78.
I do not know if I will be able to get all of them or not.
I really don't care-- ESPN, HBO, the others are fine. It is a boat.
I use an antenna for local high def. Not sure if boat gets local high def (via satellite).
It is pretty amazing watching high def while cruising the Chesapeake Bay.
Short answer-- yes it can be done.
Cost me $1200-- but I did nothing (contractor did all).
Good luck
It can be done, however at this point we opted to go with standard TV from Direct and I can watch Hi Def on my local antenna if needed. It is my understanding that the above poster is correct an ad on box is needed and it is a different satellite for most if not all of Direct's HD programming. I want to wait and see how the conversion shakes out before I upgrade the KVH. Again we are happy cruising the South Jersey area and being able to watch almost 250 plus channels. I have more channels on my boat then my home cable system. Regards Bill
It's time to try a sling box, for $200-300 you can control your home tv setup anywhere you have broadband access. Even your broadband phone. THe quality is very good.
Slingbox is a nice gimmick however not reliable enough if you do any real off shore or remote cruising. Verizon has also been known to cancel data contracts for people using excessive bandwidth (streaming video). Based on my boat's Sprint EVDO set-up which includes the LinkSys router a S720 Novatel data card driving an external amplifier and arch mounted digital antenna the service would not be anywhere near as reliable as my KVH. High speed cellular system data/service is not available in many areas of the country mainly the major population centers (where the money is). I guess it would work ok if all I did was watch the TV at the dock defenately not swinging on the hook in some of our remote rivers in South Jersey or while out in the ocean past 8 to 10 miles. Then again I need the bandwidth for my internet communications to my office and customers not being hogged watching TV.
Take care. Bill
Actually none of the the mobile satellite systems will let you get the newer KU band signals at this time. (I believe thats the band name. This info is accurate as of a month or so ago which is the last time I checked it.)
That doesn't mean you can't get HD, you can, just not all the channels that are available to home users.
from KVH
* DIRECTV has recently placed Ka band satellites into service to provide high definition local channels to home users in select markets. To enable this, DIRECTV is installing new, larger dishes for their subscribers to receive the Ka band content as well as the current Ku band high definition and standard definition programming. KVH and all mobile satellite antennas support only Ku band reception due to size constraints and other technical complexities. As a result, KVH cannot support reception of Ka band high definition locals.
Yesterday at the boat show I spoke with their rep. They are looking at it but the challenges imposed by the new frequencies are daunting. Where they used to be able to allow slop in alignment that was about 5 degrees, they need to maintain 1 degree now. As well, the LNBs are different. To squeeze all of this into a single unit poses significant challenge.
Don't hold your breath was the response I got to when it might be available. At this point it would seem that they have gotten to the point that they know they have a problem and don't have a plan to attack it.
Originally posted by Double D
Are they both just single axis ?
Yes, both Track-It/Follow-Me and AzTrax are single-axis. However, such systems work fine at anchor. The only time there would be an issue would be under way. This is the same for the KVH TracVision M2, which they advertise for "at anchor/dock". But as others said, depending on the boat, the KVH probably looks better. For me, that isn't true, so AzTrax works best. However, the KVH systems take the guess-work out of aiming at satellites. With the other two, it does take a bit of knowledge.
As for HD content, everybody is correct who said that with a KVH antenna, HD content on DirecTV will be lacking. Note that the KVH M2 and M3 ST are DirecTV only. All others (including the two single-axis brands) are compatible with Dish Network. All HD content on Dish Network would be available and Echostar (parent company) has no plans to change this. Their main upgrade to their HD content was a switch from MPEG2 to MPEG4, which took place this past Summer and did not impact antennas.
Thus, not only do you have to decide which antenna to go with, but which of the two US-based DBS companies provide the on-board content you desire.
