Originally posted by BillK
This brings up a question I have wondered -- I have always used a stabilizer during the winter. I've never had any issues with fuel. I know the marina I buy gas at does not have ethanol, however being a ski boat kept at our house, we frequently put gas from cans in, again try to avoid ethanol, but sometimes you don't know. Also, other than winter, we run through our fule within 2 weeks. Are you guys starting to routinely treat your fuel?
Originally posted by JackB
absolute...what is your concern with mixing ethanol and non ethanol fuel?
If you have fuel that has Phase Separated and you have either two or three layers you should arrange to have the tank pumped from the bottom to remove the one or two bottom layers containing the water and or the Ethanol/Water mix. (Note: you should check again with the paste before the technician leaves to be certain that all the Water and Water/Ethanol has been completely removed). You do not need to remove the gasoline. Check with water finding paste after 24 hours. If no red or yellow present then add clean fuel to the tank to working capacity.
