I've tried using mono, flags, scare balloons, mylar tape, and "bird spiders".
To effectively use mono, it must be high enough off the surface to be protected that the bird's legs cannot touch the surface w/o getting tangled. If it is just a couple inches above, the gulls don't care and will sit on top.
This means you must have some place to attach the mono and criss-cross it. Typically for a bimini, you need minimum 3 points, or 4 (better). I've found that unless you have a couple of antennas, or a fishing/radar arch, there are not enough attachment points for mono to be useful in deterring birds.
I had big hopes for bird spiders, hoping they would not need wind to be useful. They ended up being not very effective, and were forever becoming tangled. Plus they are unruly when trying to store them.
This year I'm using a Gull Sweep to protect the canvas top, along with a retainer device to keep the sweep from being blown off. For the fore deck, I'm using some nylon line zig-zagged between the bow rails. Since April the combination has been 100% effective in deterring gulls, as judged by lack of bird guano on the boat. I've had only one aerial "dump". Lots of boats around me have significant evidence of sea gull activity so there's no shortage of birds.
