Bought a 1986 390 Express last November, it is a 2 hour drive away so a pain to get ready for the water. The only thing I can't figure out is that the Vacu Flush pump works and creates good suction but it won't shut off unless you use the breaker. Normally I would say the vacuum switch is bad but I can't locate the switch or the vacuum tank it's supposed to be mounted on. This is the type of Vacu Flush that has the old type diaphram pump mounted separate from the vacuum tank. Does anyone know where the vacuum tank and or vacuum switch is hidden in this boat?
