sea ray cabin floor
fad2blac
Hi
I purchased an older 1976 sea ray cuddy cabin, tearing it all down to redo all within. their is a crack in the floor at bottom of the stairs. i cut a 2in by 2in margin around the crack exposing some wet "smelly" foamish substance beneath. any ideas on what aproach i should take to remedy the issue would be greatly appreciated. must i cut it all out where wet and replace?
thanks in advance
Mike T
sorry if i am in the wrong forum or my question is to simple but everybody has to start somewhere :)
As good a place as any to start. Not sure if this floor is balsa or foam cored--probably balsa. You need to cut out all of the core which is wet. I would cut only the top layer of glass--leave the bottom layer. after removing all of the core, then put a layer of glass mat, with polyester resin on the bottom, then layer a new balsa core or Nida core (hex cell PVC) and then rebuild the upper floor, with two layers or 12 oz bi-axial cloth. Finish with gel coat, thickened with cabosil, and then roll this out with a long nap roller. This will leave a good non skid surface. You will have to develope techniques of working with polyester resin--but that is probably beyond the scope of a direct answer about this specific problem. There are good sites on the internet on replacing cored floors. Google "replace cored floors"
hi, thanks so much for your response bob. it is foam cored :).
thanks Flutterby :)
No worries on where you posted Mike. This is as good a place as any on this forum.
Welcome to BoaterEd and good luck with your project. You sound like you're pretty handy with the tools.
We LOVE to see projects underway, so please don't be shy about posting all manner of pics.
Cheers,
Paul
