Sea Rayder Carb
tim777
Looking for a carburetor for 1994 Sea Rayder jet boat 90hp mercury..
My brother has a similar Rayder. Had his carb rebuilt this year.
There is not much to fail on those carbs, they are very simple. What is your problem with it? I found they foul up in the vent line (specifically the T fittings) and cause the carb bowl to overflow since the trapped air cannot get out and obviously doesn't make the float float.
try pulling them off (they are on the left side of the engine with a clear yellow hose line that runs up to the top of the fuel arrestor. you can try pushing a wire through them and make sure they are not gunked up.
otherwise I don't know where you can get the carbs, but when I had this problem- none of the mechanics could figure it out and I was ready to buy a new set of carbs, until I saw how much they were from Mercury - and how easy the fix was.
Someone broke off piece that holds float bowl pin is the reason for another carb...thanks for reply
