SeaDoo 2005 GFI "Help"
Moderator
I have a 2005 Seadoo, fuel injected 100 hours or so and just developed a starting problem.
Here's the background of the problem.
Daughter was using it this weekend, got a call that she fell off it (pulled the key out, which stopped the motor)got back on and it wouldn't start. She was towed in put the Jetski on the trailer and brought it home.
When she got home I put the key in and the jet ski started. So I said Hummm, WTF, pulled the key out wetted it down and then tried to start it….. 2 days later it won't start…
Do these electronic keys go bad?
Does it beep when you plug the lanyard in? Do you have the other lanyard (learning key) you can try. If not, check for corrsion on the pole and lanyard contacts. If it is beeping at all, you can troubleshoot it based on the beeps.
It is beeping, no corrision, how do you trouble shoot based on the beeps?
There is a chart in the troubleshooting section of the owner's manual, if you don't have it you can download the pdf from www.seadoo.com.
Sounds like its on its way out, I will take it off your hands for $1000.
Thats easy.........plug in the key....count how many times it beeps in one hour......then look that count # up in the troubleshooting guide....it will tell you what part needs to be changed..........good luck !
Walter, eventually either 1)the beeping will become intolerable or 2)your kids complaining that the SeaDoo is broken will drive you crazy....then after a trip to the SeaDoo dealer and a check all will be back to normal. :)
Walter, I have the same Seadoo and there are no beep codes for that engine other than the initial 2 beeps and an overheat warning. Did you pull the plugs out and ground them and turn it over to see if water came out? Is the fuel selector switch turned on?
If its beeping and the engine not turning over, it could be the solenoid, it was the culprit on mine
Easy fix. One day last year, mine would start but would not rev up. No vibration and sounded like it was running on two (both) cylinders. I was sure it was a fuel problem. Wasn't. Changed plugs and all was well.
