Searay 33 Sundancer
32carv
Well-known member
I'm looking to move from my Carver 3227 to a 1993 or 1994 Searay 33 Sundancer. I like the layout in the cabin and want to get away from a flybridge boat. What are the +'s or -'s of this boat? Are there other similar size boats that I should look at as well?
I had a 1993 330DA (model run 1990-1994) and a 1998 330DA (model run 1995-1999). Without going into detail, I didn't intend to move sidways, it just kind of happened from the circumstances at the time.
The '93 was my first twin engine cruising boat and we loved it. The relatively wide beam gave a nice ride. Those models were known for the side windows and deck hatches to leak...check for the tell-tale stains in the cabin and the caulking (usually sloppy) around the outside.
I'm not up on the pricing of these boats, but if the $$$$ difference is in your budget, and Sea Ray is your boat choice, then I would also look into the 1995-1999 330DA for the following reasons:
-Later models had underwater exhaust and the boat is MUCH MUCH quieter when on plane.
-Later models (I think in 96, but not sure) came from the factory with dripless shafts.
-Later models had the electrically lifting engine hatch which gives MUCH better engine access.
-Later models had the foot operated switches for the windlass
-Later models had the forward facing arch which was higher and depending on how tall you are, you may actually be able to stand at the helm.
-Later models, IMHO, had a more ergo layout down below and especially in the cockpit.
-Later models came with the extended swimplatform.
-Later models, (again I think '97) had EFI motors.
-Later models had westerbeke genies instead of the quicksilver
The boat market is VERY weak...you might be able to swing a good deal on a later model, but if the 93-94 is what you want, you would still be getting a very nice boat...just different. From memory, the difference between the 93 and 94 330DA is mainly the Dash on the 94 model is all white....
Good luck with your search....
I was looking into these as well. I am now sold on a late 80's Trojan 10 meter due to the larger beam and better engine access. However, I have spent osme time on them and I think they are very nice boats. I agree with the above comments to go for 95 or later. When I looked at them there were definite differences.
You are looking do move down in interior room and loose the fly bridge? Can I ask why? Seems like a backwards move to me.
I have also looked at these models. I like the cockpit layout of the 96 and later models with the u-shaped seating.
One thing I would like info on is the closeness of the engines. It seems in all the sea ray's I have seen the engines are really close together compared to similar boats. Even on the 33 with its wider beam. Any paticular pros or cons to that setup? Thanks.
Just time for a change. I've had the boat for seven years and just want something newer and different. The tunnel drives on the Searays also make it a little less risky when backing into some of the islands we visit. The other reason to go to cruiser style is that we have two bridges on our lake that I can't get under for the first part of the summer until the water goes down.
Seems like a good explanation on why you are looking to go from the Carver to the SeaRay. Good luck there are plenty of 330DAs on the market to choose from.
The newer the Searay, the nicer. I know of some that are older and are no different than other boats of the same year models. But Searay has started to make a lot nicer boat in the past few years. They went from normal to outstanding. But so has the prices.
I'm looking to keep the overall cost down, that why I'm interested in the mid-90's versions. Also, it appears the the 33' was called a 30' or 31' around 1990. Does anyone know if that is true?
In the 1990 and 1991 it was called the 310....in the 1992,1993 and 1994 it was called the 330....same boat...
I have a 1997 330 and love it. No complaints at all except maybe the fuel consumption. I just like to cruise slowly around our lake, so the 7.4s are more than I need.
The engine room is a little tight, but most everything can be reached with out much problem, and I'm no little guy.
The layout is great, and I plan to keep it for a long time.
Good luck with your decision.
Engine Room Space -'97 330DA
I am average height and a little over average in weight for my height, and I could get to all of the regualr maintenance parts. Yes, I had to be a bit of a contortionist for cetrain things, but I got to them.
Our '97 330DA did not have a genny, so that left a big space on the starboard side by the transom for me to sit in. There is space on the port side forward the holding tank to sit in. I could stand between the motors at the forward bulkhead wall and in front of the blocks. You can't get between them. I could get to all of the spark plugs to change them. That being said, I had to be creative to get to a few of them.
I had to change one of the bilge pumps. I had to lay between the exhaust hoses from the port side and stretch over the stringer to get to it. Also, my legs were in the air to get completely down there to do the wiring and caulking/screwing down of the base.
330's with a generator have a different layout. The open space I described on the stbd side is where the genny goes. This also makes the hot water heater move from aft of the stbd gas tank to the port side in front of the holding tank. That would create a lot less space for moving around down there.
In all, I thought there was enough room for me, and I try to do all of the work I can.
Whatever you choose, aside from the requisite survey, check the length in the forward berth. The starboard berth has more space than the centerline berth.
Domenic said:
"The '93 was my first twin engine cruising boat and we loved it. The relatively wide beam gave a nice ride. Those models were known for the side windows and deck hatches to leak...check for the tell-tale stains in the cabin and the caulking (usually sloppy) around the outside.
YUP
-Later models (I think in 96, but not sure) came from the factory with dripless shafts. "YUP"
-Later models had the electrically lifting engine hatch which gives MUCH better engine access. "YUP"
-Later models had the foot operated switches for the windlass "YUP"
-Later models had the forward facing arch which was higher and depending on how tall you are, you may actually be able to stand at the helm. "NOPE" unless you are 5'8" or shorter.
-Later models, IMHO, had a more ergo layout down below and especially in the cockpit."YUP"
-Later models came with the extended swimplatform. "YUP"
-Later models, (again I think '97) had EFI motors."YUP"
-Later models had westerbeke genies instead of the quicksilver "YUP"
later,
dominic
Go for a 98 to 99. Mine was one of the last last 1998's made. I was lucky. I have the 99 maple interior and the 98 and below side berth. It works well for me.
The starboard berth is 7' long vs the centerline berth at about 5'3" on a good day.
WRT the standup bridge room. I have a custom hardtop. It hits me (6'4") at my neck (5'8"). The fact remains, you can't confront physics and win. I have two choices with my 330; raise the hardtop or the helm. The former costs several thousand dollars. The latter costs a couple of 2X4's from HD and about 9 SS bolts.
We had a 40+ foot aft cabin. We sold it two years ago thinking we're out of boating. With The Admiral's persuasion we are back. We downsized to a 1998 Sea Ray 330 Dancer. No genny with full camper canvas by Great Lakes.
It is smaller, no question. Fewer stairs to navigate is a plus for us. It meets the Admiral's minimum requirements for a weekend overnighter so she can still hang around (read that "shop") with her buddies. It is big enough to cross Lake Michigan and has all the necessary equipment.
Visibility is OK but nothing like on a bridge boat. I did not buy a boat with a genny as we never hang on the hook and I have a redundant battery. Our previous boat had a genny and it was one more thing to maintain with no beneficial result. The full camper setup is a very big plus. At 33 feet this gives us a lot more usable space especially when the weather dictates. I don't like the sloping canvas on most express cruisers. When in place you can't sit on the back seat and it is a pain putting up and taking down. The Admiral does not like the curtain set up for the V-berth. She wants a door. They start at about 37 feet at Sea Ray. The only problem is a leak in the fresh water system. It probably is one of the connections. I'll try to fix it this spring. I hope it is not the water heater.
I bought the Sea Ray because it suits our current needs (The Admiral may not entirely agree) and they are very popular here and should have a chance of selling when the time comes. I do like the through the windshield doors on the Cruisers, Inc boats.
Consider a 1995, and we just happen to have one for sale :-)
http://www.usedboats.com//index.php?section=search&boatId=1400395&site=usedboats.com
The 330s are fantastic boats. We have been very happy with ours. We are looking to step up to a 2000 410 Sea Ray. Happy to answer any questions you have about the 330 as I know ours inside and out.
Note the V-Berth in the 95 and 96 is wider/longer than in the 97-99 models (from what i see, never actually measured it), which is why we went with our 1995, since I am 6'3" and needed the extra width with the Mrs next to me.
Make sure you get hydraulic steering - it was an option at least in 1996. Cable steering just doesn't get the job done in that boat.
Greg's boat is meticulously maintained. He's a few slips down from me.
Break
Bliss,
Check the connection beneath the cockpit sink faucet. That is where I found my leak...at least one of them!
Our 1995 has the underwater exhausts, neighbors does not, wow, what a difference in the noise level. Our 95 has the dripless shafts. Our 95 has the electric engine hatch. We have a Kohler genny, pretty much trouble free. Neighbor has a Westerbeke that is giving him fits.
We looked at a 2000 Cruisers Yachts 4370 yesterday that did not have an electric engine hatch. The hatch was easy enough to lift but I though that was odd.
MrsRobinson:
Your boat looks perfect but a little out of my price range for now. I don't have a boat payment and am trying to keep out of that situation if possible. Thank you anyway.
I have a 98 330 dancer and love it. We take several trips across lake erie every year and have never had a problem. Fairly good fuel economy at .90 MPG at 3300 rpm at 25 knts. May sell mine this year--going to look at a 39' exprs this weekend. Good luck and you won't be disappointed with the 33.
